ofna 9.5 violater what do i do???
My Feedback: (83)
KS
Ok i'm at the end of my ropw...i try starting it with the roto-start and it was working fine and then it sounds like its not engaging in the back of the motor and i just change the back plate? what am i doing wrong? also where is a good cheap place to buy the backing plate for the roto-start? thanks Terry
RE: ofna 9.5 violater what do i do???
Sounds like the one-way bearing in the rotostart is probably slipping. There are many motors out there with many different backplates. What motor are you running exactly?
