ZRB-1 PARTS
RE: ZRB-1 PARTS
Do you currently own a ZRB-1? If so, do you race it often and how is it holding up for you?
Irecently came across this ad for one but was having a hard time locating parts until I saw your post:
http://www.leaderhobby.com/product.asp?ID=9394001224072
Thanks!
Thanks!
RE: ZRB-1 PARTS
he no longer owns this car but he had alot of issues with the screws coming loose, the shock springs were junk, to soft, all of the suspension had alot of slack after about 4 runs, the idler gear output shaft is pinned and the pins break, and the motor fried about the 5th time he ran the car, the body shattered like i have never seen one shatter before during a crash. it was in about 4 peices. it wasnt even that hard of a crash. also the stock remote is junk, he replaced it with a traxxas and the batteries they give you are not so great.. other than that it was tops, lol
RE: ZRB-1 PARTS
Thanks for the heads up... sounds like most of those issues can be resolved with upgrades, however which pins were failing? Suspension pins, CVD pins, etc? You make it sound like the pin which holds the idler gear failed and I've never heard of that pin failing on any car before, though Ihave heard of idler gears getting stripped
RE: ZRB-1 PARTS
i think the screw holding the idler gear may have come loose a couple of timescausing the failures. also the esc is mounted right behind the front steering/suspension brace and it actually touches the esc. one hard hit and you have problems. the battery connectors were junk.the front shock mountbent very easily to and a rear drive shaft pin also broke. keep in mind this is all in about 5 runs on a track. i would seriously look into a better car. its not much fun to run a car when its breaking all the time. if money is an issue, look into a good used name brand car.
RE: ZRB-1 PARTS
Sounds like good advice to me, I'm definitely interested in something that will last a full season before having to replace parts... I'm bumping up from 2WDSCT and the Losi has proven very reliable for me, Imay just stick with that brand or something similar, thanks!
