OFNA LX2 converted to on road ?
Hey everyone
I bought a pile of stuff of a guy yesterday and he said this vehicle was a Ofna LX2 buggy at some point that has been converted to an on road car.
Ill just post some pics of it, and let them do the talking.
I would like to convert it back to a buggy if possible... or I will just sell it as a roller.
What would be needed to convert it back ? Shock towers, front shocks, ?
CA
RE: OFNA LX2 converted to on road ?
ORIGINAL: tyhatts
Hey everyone
Hey everyone
Lookis like an Lx1 I only run Ofna and have or have had almost every buggy they sell.
All you need is shocks, shock towers and original body mounts. I think you would be set.
Thanks for the info..... I made a rookie mistake with this package and got screwed I think. It came with a 454 motor in peices that I "only needed a crank" to fix. Well... turns out I need a carb, Crank, and I think the sleeve is the wrong sleeve because it will not go in the block.
This car Im not to worried about, as long as I can turn it back into some kind of buggy... Or if I can leave it and make it a rally car ?
ORIGINAL: tyhatts
Thanks for the info..... I made a rookie mistake with this package and got screwed I think. It came with a 454 motor in peices that I ''only needed a crank'' to fix. Well... turns out I need a carb, Crank, and I think the sleeve is the wrong sleeve because it will not go in the block.
Sounds like you did get a little screwed with the motor on that one. Carb is gonna cost you a few bucks more than you want it to. The sleeve the same thing. The piston again more money. To save a little bit of money you may wantto check ebay they have engin parts. Good luck with that. If it were me I would set the 454 aside and buy a used or new buggy engine from some one or some place. So worriying about switching it back to a buggy is the least of your worries.
If you need help feel free to contact me here or via personal E-mail. [email protected]
