If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 7 of 7
  1. #1
    Join Date
    Apr 2006
    , NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cleaning bearings for bashers advice neeed....
    Bashing scenarios.....dry, damp, streets, lawns, ditches, gravel, dirt, asphalt.....ripping hard, but not abusing the nitro buggy to much.
    Buggy is cleaned pretty thoroughly with Nitro Spray Cleaner, dried with a heat gun, then I hit the bearings/dog bones/joints as best I can with some sort of light oil spray lube or Bananna lube or something before storage.
    Questions:
    How many tanks before I should remove bearings from housings on buggy and do a thorough cleaning?.......wheel bearings?.....diff bearings?
    What should I lube thgem up with after cleaning for max protection and longest time between cleanings?
    Thanks.
    Got time to breathe.....got time for music.
    TMAXX 3.3, RC10GT, DTX 835B
  2. #2
    Join Date
    Aug 2007
    Roseville, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Cleaning bearings for bashers advice neeed....
    All you can reall do is hit them with a shot of wd40 or similar substance. You can try and pop the seals off and clean them, but its tough to do, usually if thier rough just replace them.
    ((((((((MARSHALL!!!!)))))))
  3. #3
    aspeed's Avatar
    Join Date
    Jul 2011
    Ruthven, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    An air hose works good.  Oil attracts dirt, so if you use it, it will need to be cleaned more often.
    Glow Head Hood # 7
  4. #4
    Join Date
    Apr 2006
    , NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks....what I'm reading/hearing is.....since bearings are sealed, fairly inexpensive and unless I'm gonna go thru the PITA of removing seals & lubing....I'd be better off just blow'em out with an air hose, hitting with a WD40 type of light oil spray and replace when they show any signs of crunchy-ness/wear...
    [8D]
  5. #5
    ORIGINAL: flatpickhippster
    [8D]
    Exactly. I use fast eddie bearings, quality bearings and free shipping over 20.00.
    http://www.fasteddybearings.com/
  6. #6
    Anthoop's Avatar
    Join Date
    Feb 2007
    Somerset, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    [8D]
    Well there has to be someone to disagree, so here I go....
    If I have got enough dirt around the bearings to cause me to worry, then I flip the sheilds off- bath/brush in degreaser- dry- relube- refit sheilds.....and yes I do more maintenance than driving, I like it.
    Sheilds are easy to remove with a scalpel around the inner or outer edge and try to flip it off....when removed give it a blast of air and a thorough wiping...and check it is still flat.
    I bath the bearing in degreaser but there are plenty of other options like brake cleaner or specific bearing sprays....or anything that will wash out the existing grease without leaving anything behind (that we do not want).
    For lube, I use bearing grease....again there are many options but for bashing around, some auto type grease is fine.
    I would not be tyring to wash bearings through whilst the shields are on as you have more chance of pushing dirt in and also washing the grease out....either leave it alone or do it properly.....cheap bearings are cheap.
    If a bearing feels rough then inevitably it is already too late....but a good clean and some real thick treacle will make it smooth again, just a bit slow.
    When I die, I want to go in my sleep like my grandfather,not screaming
    like the passengers in his car at the time.
  7. #7
    JohnP2's Avatar
    Join Date
    Dec 2011
    TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'll service wheel bearings about every10 tanks. I just spray them down with a llittle contact cleaner to get initial crap off, pop off the shields, spray the insides good, and then use some Hudy bearing oil (just a little) and they come out like new! With that said, I'll only clean them once...because if you pop off the shields too often (at least in my experience) they wear. I'll also get fairly inexpensive wheel bearings since they are replaced every20 tanks or so.
    Clutch bearings I just replace about every 10 tanks or so...once again I'll go with inexpensive ones. Diff bearings I'll replace when I service the diffs (maybe every 3/4 gallon), butpreferhigher-end ones since they don't get replaced too often.
    One note about removing rubber shields.I recommendan X-ACTO knife (hobby knife) likethe pic belowto save you a lot of frustration. ;-)
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    MBX7, MP9 TKI3, XB8, NB48, 8 3.0, X 4.6, 810, Hyper 7, A8T,
    http://www.youtube.com/user/NitroRCNerds
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
