Futaba 3PM-FS TX & R133F RX Query
[h=2]Futaba 3PM-FS TX & R133F RX Query[/h]
My steering channel(1) suddenly stopped working, I have swapped my throttle and steering servos around on the Receiver and both servos function correctly. I have also tried the steering servos on channel 3 and it seems to respond fine.
Any ideas why my steering channel might have stopped working, thinking I might need to purchase a replacement receiver??
The trim does move the wheels slightly, if I set the trim to 100 LFU I'm able to turn the wheels slightly each way. I get a high pitched frequency noise from the front servo when trying to turn the wheels, I'm using Hi-TEC HSC-5998TG servos.
The throttle servos is responsive and almost silent, soon as I use the steering channel I get a high pitched noise and not much movement from the servos arm??
