clutch dis-engaging
clutch dis-engaging
Had a question for you. I recently put a RB in my pcr pro. The problem is when letting off the brakes, the wheels spin without throttle. Is the clutch not dis-engaging? If so, how do I fix it. Thanks.
RE: clutch dis-engaging
No, it does not die. The car will actually go forward. These are new shoes and springs. Could I have installed them backwards?
If you can hold the car still and doesnt die, your idle may be too high? try bringing it down a little
I dont think you can put shoes in backwards? They either go leading or trailing edge and that would not make a differance in your case.
thats righ, you cant put shoes in backwards, many pply i know put their shoes in differently coz it affects the bite of the clutch....probably you needle like he said
