P5, S5, S7...Need some help.
CT
After spending HOURS reading through the posts on various engines, I am hoping to get some help to determine what the differences are between these 3 engines...P5, S5, or the S7. I race on a tight, medium length course on hard soil with limited traction. My car is an MBX5.
My priorities are...
1. Reliability/Longevity
2. Holds a tune
3. Performance
Of the 3 engines and my priorities can you suggest which engine you would choose and why?
Thanks for the help.
2. Holds a tune
3. Performance
IL
RE: P5, S5, S7...Need some help.
well that sounds like my track and the P5 and S5 are both great and hold a tune very well. i run the P5 and my good friens has the S5. we are very close but i have a bit more bottom than he does. i also have the S7 but i just keep putting the P5 back in. i hardly ever have to mess w/ the needles. the S7 i have has been modded also but it just dont have the punch that the P5 has. it is smoother(S7)not so agressive but i like agressive. ALL 3 are great motors i think it just depends on your driving style?
AR
On a tight track the order like HP1 said is P5, S5, S7. And if broken in properly, they all will last several gallons. I have 5 gallons through my S5 and it still has great compression, when it dies I'm going to get another one.
My Feedback: (8)
AL
i have the S7II, and can vouch for its reliability, and very good performance. it is a happy high revving engine, but offers little in the low end grunt department. however, you can compensate for this by installing 1.1 clutch springs. i also just received my WS7II, but don't have the pipe yet, and have also installed 1.1 clutch springs. these stiffer springs allow for the engine rpm's to spin up a bit before the clutch engages, allowing you a violent exit from tight turns.
Have you considered the v-spec? All the engines you mentioned are good, although I have seen and heard of many problems with the P5.
you will want to consider avalability of parts too , the P5 parts are easy to get whereas the RB range a a little harder..
ORIGINAL: Alden
Yes they both have problems.. the V Spec has a rear bearing problem, it goes within the first 2 gallons , and the P5 has been known to Shatter pistons. Both Problems are easy fixed..
IL
ORIGINAL: Alden
Just my experiences, just like you experience flameouts and tuning probs with the v-specs u have seen while at my track none have problems.
CA
ORIGINAL: MassiveMods
ORIGINAL: Alden
yes there are problems they are. Bad tuners, bad maintenance. and they are both easily fixed ~ usually.
ORIGINAL: hyperpmp1
you gotta be kidding me? ive NEVER heard of any probs at all? and ive seen lots of guys using them. as for the JP's just a waste of cash if you ask me? but thats just me(sorry monte) you can almost get 2 of the novarossi base ones.
ORIGINAL: Alden
hows it going hyperpmp1[8D], no need to apologise, dude but i did get the stock version, not the modified, and over here in the UK, it is CHEAPER and better (as sooooo many people have claimed) than the stock novarossi/rex/top/RS5, P5's.
honestly you are gonna have to try the stock version (just ask skyline).
i don't know the price in the US, but it's gonna be way cheaper than the UK
