RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Powermaster Fuel
Reply
Old 10-14-2005, 06:01 AM
RCDadChicago
RCDadChicago's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Powermaster Fuel
I've been using Powermaster fuel for awhile now. I originally bought it because a) they make Traxxas Top fuel, and b) it's inexpensive.
Yesterday, I had my Ofna MBX Pro out and I just can't seem to get it tuned correctly. If I lean it out it doesn't like to idle, at 3 turns (HSN) it idles real good but boggs when you really give it fuel.
I'm wondering now if it's the fuel?
RCDadChicago is offline
Old 10-14-2005, 06:17 AM
scale only 4 me
scale only 4 me's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Powermaster Fuel
Did you change the plug first?
Whenever "all the sudden" it's not running well,, I like to put a new plug in before I mess with the neddles to much
scale only 4 me is offline
Old 10-14-2005, 07:22 AM
slicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree -- check the plug 1st -- if that is not it and you are running with a force .26 it sounds like the normal progression for that engine.
slicks is offline
Old 10-14-2005, 08:04 AM
RCDadChicago
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I did check the plug and it looks good. The engine has good compression but can it still be wearing out? I'm thinking of seeing if my HPI k4.6 engine will fit in this buggy.
Old 10-14-2005, 10:00 AM
slicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is this a Force .26 engine? They just seem to start having a lot of tuning problems (some sooner than others). I have seen where the needles move on them while running, or the carbs develope air leaks - the problems just go on and on with that engine. Most either replace the carb with an OS carb or just plain give up and buy a new engine. My daughter and I both run OS RGs now and love that engine.
It is worth a try to see if the other engine will fit.
slicks is offline
Old 10-14-2005, 12:53 PM
kx250ryder
kx250ryder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Assuming you have a working plug, and you have good compression try this:
**NOTE: temp. gauge required for the following**
1.) Reset needles to stock settings, including the idle (you may need to lean slightly over stock settings to keep car running)
2.) Warm car up until chassis gets hot, making sure temps never exceed 250
3.) Lean HSN to keep temps between 220-250 making sure smoke is visible between low to mid RPMs
4.) Lean LSN until pinching fuel line near carb causes engine to stall between 3-5 seconds
5.) Check to make sure low end changes haven't made motor exceed 250, if they have richen HSN
6.) Adjust idle as high as you can without the clutch engaging (car should not move).
7.) Re-check above any time outside weather changes significantly, or at the beginning of a day of driving
kx250ryder is offline
Reply
Display Modes
