**** TUNING GUIDE **** The Alex way.
#51
RE: **** TUNING GUIDE **** The Alex way.
ORIGINAL: sh0wtime
i'd forgotten about this thread & the fun we used to have on here
so what you're saying there is you had to re adjust your LSN after adjusting the HSN because adjusting the HSN had directly affected its setting.
therefore in order to get your engine set perfectly you adjusted HSN then LSN
thanks for backing up the points raised earlier
ORIGINAL: Nathan9492
Well.
Ive tried Alex's (Da Smak's) Way of tuning, So i set my LSN first, then proceded to the HSN, I got it running good. I did needa do a tiny turn back on the LSN since it was racing a little bit.
Well.
If you dont like the tuning method, Why keep on whinging?, There is soooooo many different methods of tuning, and running in that theres just no point.
Hell, I know a guy that Idles his engines through 7 tanks, and they go really strong, i also know of a guy that leans them right out straight from the factory and Runs them HARD during break in.There still going strong aswell.
Im in now way having a go at ya, Just trynna get a point a cross that there is many ways of tuning a nitro, And really, IF you can get your car to run really good, with a nice trail of smoke, no hesitations from bottom to top, then ur tuning method worked, FOr me this tuning method did just that, IN a easier way then i used to do it.
#52
FL
If you read the post properly it is a book and dvd. I've been looking but I can't seem to find the book or dvd you have had published. Which is endorsed by Radio Control Car Action magazine, Radio Control Nitro, RCX, Tinity, AE, Traxxas. I'm not saying your wrong, I am simply saying you can read the book and watch the dvd and leave this forum more informed than when you camein. You just aren't following industry / racing standards. You have to be willing to learn. The best teacher knows they can always learn more.
#54
MO
Is there a way to tell if the motor is completely broken in? I busted a con rod in my last engine and really don't know why. I want to avoid this on my new one. I have about 10 tanks through it now and it runs and starts great but I want this one to last. It is a hyper .21 8 port race. When I turn the flywheel without the glow plug in it stops at the top. Is this normal?
#55
Hi Fazz.
YEs that is totally normal For the piston to stop at the top of the sleeve.
Thats a good sign that there is compression and Pinch.
IF there was none there, then you have lostt compression, Basically means ur engine is shot.
#56
how about if ya turn the fly wheel over by hand and at TDC it has a rock (like movement in the fly wheel) without the piston moving? im thinking a flogged out con rod????
#57
Your flywheel maybe a bit loose?
Check that its tight, before jumping to the conclusion that u have done something internally
#58
Banned
ORIGINAL: *FULL-REVS*
But I have 2 engines that have a lumpy feelat TDC and they still run fine. It's more noticable on short stroke engines too btw.
#59
yeah it runs fine when cold but when it gets warn it develops a low down bog.....(without adjusting anything) its starting to do my head in.....tried everything....fuel tank and lines, plug, retuning, bearings are spanking new as is piston and sleve.... broken in well and performed well for a short time then started playing up.... have stripped and sealed carb,back plate etc....
#62
Banned
#63
Do you have to turn your engine off when breaking in? i ran it richer than normal, then started leaning it out at about the 5th tank. but never turned my engine off during gas refills.
#64
It is adviseable depending on the method you use.
I always use the heat cycling method which requires stopping the engine and cooling it.
#65
ORIGINAL: MassiveMods
What i wrote was the method or didnt you read my post you moron ... and you are contradicting yourself you state "5 tanks on the box at idle " now your saying its just to mate the liner and piston.. what you should do is make a video of the piston and liner mating and connecting a boost bottle to your head .
#66
ORIGINAL: glypo
Looks to me like someone is getting a little defensive because they are wrong, and have trouble admiting it.
Slodsm may not be the world champs mechanic, but I know if I was the world champion I'd at least give my engine to the guy who starts tuning with the right needle first.
