engine cleaning
engine cleaning
yea i got my OS RG engine and it mas been a real pig lately manly overheating, i was wondering is this is something to do with the engine been dirty on the inside.
could i get some advise on engine cleaning?
thank's for any help!
NJ
RE: engine cleaning
most likely its your tunning ,but this might help you out a little .
http://www.*********.org/cars_nitro_tasks.htm\
http://www.*********.org/cars_troubleshooting.htm
RE: engine cleaning
Outside getting dirty? Help keep it cleaner, spray the outside down with wd40. head and all, take shoes and bell off. wipe it dry, run it around and the dirt on the outside will all but fall off. If its the inside, no clue, sorry.
VA
RE: engine cleaning
ORIGINAL: p0u1burke
How many gallons do you have through it?
How is your plug?
It doesn't really matter how dirty it is on the ouside if you only keep the airfilter clean and keep it somewhat tidy around the carb.
Cooling head needs to be dusted of from time to time too.
MD
RE: engine cleaning
I actually just has a huge problem with my enigne..dirt and such..you can read it in the Mayhem Thread. But anyway I need a new pistion and sleeve, so im ordering that but with the bearings, how do i get them back into the crankcase as tightly as before..the article tells you how to take them out but not how to put them back in tightly. Also when i am cleaning the bearings, do i just spray them out with WD-40 then dry with a compressor, then oil them with 3n1 or something else. Thanks in advance!
-Erc
-Erc
RE: engine cleaning
and dip them in some nitro fuel, the brand your running will do. Heat block, chill bearings. Rinse the inside out or even soak in white kerosine. Dry well even overnight, then heat ect.
RE: engine cleaning
the engine is about two months old it's hade about 2 gallons through it and the plug is new, the engine has never been cleaned.
thanks
thanks
VA
RE: engine cleaning
ORIGINAL: p0u1burke
If the piston can be pushed above the top of the liner it is most likely worn out.
People on the board doesn't have X-Ray vision so you do need to put some effort in.
Besides do the normal maintenance routine:
- Use clean airfilters
- Check fuel and pressure lines for leaks
- Check fuel filter and clean it if needed.
- Check servo linkage, does it open the carb 100% ?
- Check clutch shoes and springs on a regular basis.
- Clean the car at least every other day of running. I know fail doing this frm time to time.
RE: engine cleaning
ok sorry i normally write these in a rush, but could you recommend me some product's to use when I'm cleaning the inside and outside of the engine.
VA
RE: engine cleaning
Regular shampoo actually works good. Make sure to seal up the carb and exhaust for the initial wash (to prevent dirt coming in)
(If you got some dirt in it it's no biggy if you disassemble everything and clean it, just don't turn it over)
Rinse in hot water, makes it easier to dry.
Lube it with WD40 to get rid of moisture
Assemble
Lube with after-run oil or ATF oil (Automatic Transmission Fluid). Be generous with it but get rid of excess oil.
Done!
Assemble
Done!
RE: engine cleaning
yes you say shampoo, is that only for the outside of the engine or for the inside as well?
and the transmishion oil, would normall car enginee oil be O.K?
thanks
thanks
VA
RE: engine cleaning
Shampoo works both inside and outside. It disolves grease and that's the only interesting thing but you need to rinse it off. Simple green works great too.
Engine oil is not good.
RE: engine cleaning
O.k that's cool and cheap for me i don't have easy access to that green stuff you were talking about I'm in Portugal, thank's
