The official Caster Buggie thread
#52
RE: caster buggie
The Pro kit is also one of the lightest buggies available.My Pro buggy is equiped with Axe Motor Rossi Black Magic enginewith 2022 pipe
Sanwa Super EXZES radio and reciever.KO 9.5kg steering servo,Futaba 3010 throttle servo.I also use lipo recievr battery.After a race car weights +- 43 grams above legal limit.Last national meet my car was lightest car at event.
#54
AZ
RE: caster buggie
ORIGINAL: yz1000
hi razzor why you got 2 filters i see you have one on the exhaust pressure pipe
http://www.*********.org/engine-tuning.htm
#55
RE: caster buggie
K250ryder is partially right.
I have filter on my pressure line because I had noticed dirt getting into the line from the pipe.
Thought it wouldnt do any harm.
On my feed line i have a reservior which looks like a large filter , this seems to help car run longer when on its roof.
Dont need a filter on feed as there is a filter inside the tank.
#57
RE: caster buggie
how about some set ups also
looks like i have hit a problem
with my buggie i cant fit a 5cell
hump pack battery and my receiver
in the radio tray i have the JR synthesized
receiver any one know how i can fit this lot ?
looks like i will have to cut the side of the radio
tray and leave part of the receiver sticking out []
#58
RE: caster buggie
is your reciever the 300 or 310? the JR 310 reciever is a lot smaller than the 300. if you have the 300, get the 310, they both do the same things except the 310 is smaller.
#59
RE: caster buggie
thanks dicko i have the 300 reciever no point in buying a 310 just cos the 300 wont fit i have 4 of them
im gonna cutt the tray and let it stick out a bit [&o]
#60
RE: caster buggie
just drove my caster for the first time today and realy drove the crap out of it through
water / mud/ ramping it hard i just wanted to so how tough it is and it came out unscathed
i think it can be a good competitor among the other brands
#61
RE: caster buggie
This past weekend ran my zx-1 Pro at the 3rd round of the SA nationals.
Qualified 31st out of 65 and this with only one good run on the board in qualifying rounds.
Had hassles with both my STS engines and borrowed a buddies P5.
Car ran awesome in round 4 got me on position 1 in D-mains.
Hope to sort out my Black Magic shortly as I am waiting for rear main bearing.
Had a lot of fun in Secunda on a awsome track with great grip.
#62
RE: caster buggie
Bought a Axe Motor Rossi Cobra engine and am itching to use it ,holding that idea for know as my Black Magic is just awesome.
Am putting a setup sheet together to help new Caster drivers.
YZ1000 great to see you having a blast with your buggy.........thats what is all about ....FUN !!!
#67
RE: caster buggie
my diffs dont leak and all my diff gears have no problems.
on neobuggy they have a couple of CAD pics of the caster truggy i cant wait
#71
RE: caster buggie
Your front track is too wide.
Turn in upper and lower pivot balls two to three full turns to keep camber the same and then adjust your steering turnbuckle to correct the toe on the steering.
I usually run a little toe out ,about 1/2 degrees.
Check camber as well ,run about 2/3 degrees negative camber.
Problem should be solved.
If you look at the dog bone end of universal as it goes in to the out drive, the pin in the dog bone should be about 3mm in from outer edge.
#72
RE: caster buggie
mindcrime thats what i thought so i did that and it seems that it will still pop out if i lift the arm up to max then it looks like it wants to pop out although i havent tryed it with them moved in yet but looks like it aint gonna work
