If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 21 of 30 FirstFirst ... 111920212223 ... LastLast
Results 501 to 525 of 738
  1. #501
    Join Date
    Nov 2006
    , IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Official Thread for the Go 21 Engine
    Yes, the race version. Also, i did not have the additional shim installed. I put it in yesterday but haven't had time to try again. I am using O.S. P6 turbo Hot plugs too.
  2. #502
    slayerphonics's Avatar
    Join Date
    Mar 2007
    Daytona Beach, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: nucular
    I'm debating on buying this engine, your post has me worried though []
    There\'s a right way and wrong way to do everything and the wrong way is trying to make everybody else do it the right way
  3. #503
    Join Date
    Nov 2006
    , IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    well, don't worry too much yet. I have broken in several engines but this is my first 'race' class so it could be user error.
  4. #504
    vnmsgt's Avatar
    Join Date
    Aug 2007
    winter garden, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: nucular
    I started breaking my 3 port in this weekend and was having a lot of trouble keeping it running for the 1st 2 break-in tanks. I had the HSN out 2 turns (according to the sheet that came with it) but i have heard other people say 1 turn out from flush which is a huge difference. It would stay running if i left the ignitor on it. The entire time it was just spitting fuel out the exhaust which tells me it was way too rich. I tried to turn the lsn in a little but then it would just run erratically. Are these pretty finicky during breakin?
    I had to break mine in with the HSN 1 turn out. 2 turns out was too much and it would not idle and stall and blow fuel out real bad. Idled the 2 tanks and then ran 3 tanks and then leaned it a half turn so it was a half turn out from original and it was fine.
    Don\'\'t jump on the bandwagon...CRUSH IT
  5. #505
    Join Date
    Nov 2006
    , IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Was that 1 turn out or 1 turn out from factory? I was 2 turns out from bottom.
  6. #506
    Jatohulk's Avatar
    Join Date
    Feb 2007
    Miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Guys there is a company that sell little dail for the HSN and the LSN for these RC engine which are good for turing the engine. Anyone use them are the GO Tech engine and if you do what is the place to get them and the name of this product I can not remember..
    IT\'\'S ALL FUN AND GAMES UNTIL YOU SMACK INTO THE WALL AND BRAKE SOMETHING!!!!!!!!!
  7. #507
    vnmsgt's Avatar
    Join Date
    Aug 2007
    winter garden, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: nucular
    The way the motor comes out of the box you are supposed to back the needle out 1-2 turns from factory. I did 1 turn out from factory. If you are 2 turns out from bottom you are WAY too lean! You leave the needles alone except the what we just wrote about for break in.
  8. #508
    Join Date
    May 2006
    Murrieta, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Jatohulk
    Do you mean these dials?
    I bought the dials from from Mark at RC Hardware.
    http://rchardware.com/
    Nomadio Sensor, BCE Cen Matrix FRE / GO TECH .21 7P, BCE Cen TR Arena FRE / GO TECH .21 5P, \"N-Tune\" Nitro Engine Tuning Dial
  9. #509
    Join Date
    Nov 2006
    , IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: vnmsgt
    ORIGINAL: nucular
    That's what I would have thought but the spitting fuel leads me to believe differently.
  10. #510
    Join Date
    Nov 2006
    , IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You know, I should have thought of this earlier but I'm going to swap out the plug. It was new but who knows.
  11. #511
    Join Date
    Oct 2004
    chesterton, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Holy crap 21 pages my eyes are about to bleed.. I decided to read this entire thread because the guy that mods my motors told me I should give them a try and I wanted more infomation.. So here are my questions.
    1. those of you that have both the 5 and 7 port turbo how much of a difference is there in bottom end between them?
    2. Has anyone put more than 6 gallons through there go tech and if so how is it holding up?
    3. How many of you have gone to ceramic bearings and why did you switch?
    4. Has anyone tried the THS 816 pipe with one of these engines if so how did it run?
  12. #512
    Join Date
    Jan 2006
    Northern, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Good questions!
  13. #513
    Join Date
    Oct 2004
    chesterton, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    JSracer where in indiana do you live I'm up by portage/ hobart
  14. #514
    Vigilante212's Avatar
    Join Date
    Sep 2006
    Menasha, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The reason anyone switches to ceramic is they last longer run smoother and have less friction. I cant really answer the other questions, but I can give you an opinion on the 5 port. The 5 port has alot of torque. Even with my 086 pipe on and a 7mm carb insert I have to limit my throttle to keep from spinning out. Top end is really good too which surprised me a bit since I was able to keep up easily on the straights and most times outrun the faster engines since I get up to speed quicker.
    On a really long straight(180 feet or more) It might be a problem, but i dont race on any track with straights that long anyway.
  15. #515
    Join Date
    Nov 2006
    , IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, I worked on another break-in tank of my 3-port R. I reverted the needles to what I read in the RC-Tech thread (just under flush on the HSN and a couple turns out on the LSN I think), I put in a new plug, and broke open a new gallon of ODonnells 30%. I was using a left over gallon of 20% from before winter - thought I stored it properly. I'm happy to report that it ran that tank exactly like I thought it should. It started right up, didnt die through the whole tank, and smoked perfectly. At this point I don't know if it was the fuel or the plug but one of them was bad.
  16. #516
    vnmsgt's Avatar
    Join Date
    Aug 2007
    winter garden, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: nucular
    Probably the fuel if it was before winter. Glad to hear you got it running good for break in.
  17. #517
    Join Date
    Apr 2007
    elgin, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: nucular
    i would try a p3 plug and keep a heat gun or blow dryer on the head to help keep the temps up. i could barely keep my engine running during break in it was so rich i would idle a tank in about 5 minutes. i currently bought a jammin 21 for my buggy to run outdoor but for indoors im buying a 3 port race to try out
    Caster Racing Fusion EX-1 Pro
  18. #518
    vnmsgt's Avatar
    Join Date
    Aug 2007
    winter garden, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I run the OS P3's too like "ecocav04" and have no problems at all.
  19. #519
    Join Date
    Sep 2006
    Menasha, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: ecocav04
    ORIGINAL: nucular
    wrap the head in tinfoil and put the cutoff end of an old sock on it it keep the temp up. It worked great for me kept my break in temps above 200 running really rich and I never stalled once.
  20. #520
    CtK's Avatar
    Join Date
    Jan 2008
    Miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I just got my Go Tech 5 Port engine and read the manual, it says to use 25-30% fuel??
    I have a couple of gallons of O'donnel 20% left over, Can I use that??
    Losi 8ight Roller with Go Tech .21 5 Port
    I AiM tO MiSBeHaVe!!
  21. #521
    *FULL-REVS*'s Avatar
    Join Date
    Nov 2007
    , NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i run both my "GO's" on 20% fuel and they are fine.... if you keep it on 20 remember to drop a head shim after break in.....
    Life is all about ass,Your either coverin it,Kissin it,bustin it,kickin it,tryin to get a piece of it,or just behavin like 1
  22. #522
    Join Date
    Jan 2006
    Northern, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Remember to drop a head shim from 4 to 3 or 3 to 2 for 20%?
  23. #523
    CtK's Avatar
    Join Date
    Jan 2008
    Miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am having a very hard time startin my GO .21 5pt engine for the first time.
    I have it wrapped in foil and had a blow dryer on it for 20mins now
    temp is around 200
    turn the HSN out 1 turn
    have the extra shim in there
    loosen the glow plug
    what else can I do??
  24. #524
    Join Date
    May 2006
    Murrieta, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: CtK
    temp is around 200
    I had the same problem you are having. I put several drops of After-Run Oil in the glow plug hole and I kept the glow plug loose. I wrapped the head with foil and I bought a heat gun from Home Depot because a hair dryer was getting the engine head hot enough. I had to get the temps up to about 250 degrees F to finally get it to turn over. I also turned the flywheel clockwise just until I felt it have some resistance so the flywheel can get some momentum when it engages the starte box wheel.
    The break-in process for a Go Tech engin can be frustrating but keep at it. You will be very happy with your engine once you get it running. Good Luck.
  25. #525
    CtK's Avatar
    Join Date
    Jan 2008
    Miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Tree1
    ORIGINAL: CtK
    temp is around 200
    I did go buy a heat gun from Home Depot and it actually got it to turn for a while but ill try putting some after run in the glow plug hole...thanks!!
    also are you suppose to use a washer for the turbo plugs??
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
