**Does it come off?**
im having a little trouble taking all the stuff off of the infinity 27 to put in the sts 30 that i just bought. After you take the clutch shoes off there is a nut you must take off, after the nut there is like the round thing that is attached to the flywheel with 3 poles sticking out. how do I go about getting it off the flywheel? the thing I am talking about is if you have a starter box, you put the starterbox on it and it turns the engine over.
RE: **Does it come off?**
Those pins stay on the flywheel, it holds the shoes (clutch) on. Just tap the back side with a screw driver handle or small wrench, tap on one side then the other, it should then fall right off.
Yes, once you've got the flywheel nut off, the rest is easy. Heat it up a bit and tap it, should drop right off. The thing with the three prongs on it IS the flywheel, as stated.
