Kyosho Inferno Us Sports
#1601
RE: Kyosho Inferno Us Sports
Ello every body, last night I was playing around with my buggy when it started to rain, it was wet and slippery.
I went back inside, sat down and started to think about how to water/dust/mud proof my shocks.
Came up with the most simple solution ever.
Took a pair of rubber gloves (normally used for doing the dishes) and cut off the fingers, cut a tiny little hole in the tip of the finger (really small cut, maybe 3mm) and pulled one over the shock absorber all the way over the spring and up to the shock cap, used a zip tie to keep it in place.
Well it works pretty good and keeps my shocks nice n clean plus if I ever blow a shock all the parts stay inside.
Cheap n eazy shock booties.
Still sitting on my ass thinking what to do with the other fingers???
Stuffed the reciever in one and then all my receiver battery packs.(zip tie closed)
Looks cool also.
It stopped raining.
Looks cool also.
It stopped raining.
#1603
GA
I picked up this MP9 from a friend thru a friend. He let it go for $200. I know it's a MP9 but I have no idea what version I have. Can anyone tell me.
Here are some pics but if i need to take a pic of a certain area to help identify it than let me know.
#1604
Hi All or Nothing, nice, you bought that for 200 buck, jeez that was really good, I paid 500euro for one last year also second hand.
Well done, you have a nice buggy there.
Looks like the TKI version but not certain(yet).[8D]
#1606
ORIGINAL: lez1troubles
Any body still alive???
#1607
ORIGINAL: R.lepecha
I am, Seems like not much is happening with these buggies anymore. The Inferno mp7.5's and later must be going obsolete.
And maybe in the future I convert my Inferno to electric and keep the xray on nitro.
#1608
ORIGINAL: Oskr
Indeed. I struggled a lot to find the spur gear. I got an original set from China. But even obsolete the car is still a great car , and I don´t think there will be a serious lack of components in the market.
ORIGINAL: R.lepecha
#1610
All spare parts can still be had at WWW.INFERNOSONLY.COM. Thats for all the Inferno models whether it be the old BURNS all the way up to the MP9limited. even bits'n'bobs from the older Kanai versions are still there to be had.
Had a great weekend racing, next weed I'm going with a couple of freinds to race a guy called Bart Loomans, he is a sponcered driver for pro team KYOSHO and I'm going to kick his butt(not litterally, just in the race), Bart is the current BeNeLux buggy champion.
#1611
Hello guys. Hello Lez1!!
Well, I just messed up another pinion & bevel gear set. IT seems it´s missing something. Maybe some washers in the diff/bulkhead to get the right fit?? How to know(measure) the the right fit?
I just run 4 tanks with the new set and the noise on the diffs started again. Maybe this time some washers may solve my problem.
#1612
Have you checked the bearings?
Make sure they're not seized.
Other than that are you sure you've got the shims from the bottom of this photo?
#1613
Like Lepecha said, you will need to shim it otherwise you'll have exece slop inside your diff.
Just shimm the satalit gears and you'll be good to go.
Have you got 2 satalit gears or 4 in there???
#1614
Thanks guys, but I think I wasn´t clear in my explanation. I messed up the bevel and pinion, not the internal gears. By the way I have 4 planetaries with the shims. Lez1, I went to 4 planet. following your suggestion when I was changing the engine to a LRP .28.
There is a shim (BS53) that goes between the diff. bearing and bulkhead (not the one in the photo) and is supposed to improve the bevel and pinion match, moving the diff toward its side. I will order some of these shims and try to change (for better) the match.
#1615
Sorry Oskr, slight brain fart there.
Its the one in the middle that you want to shim, I am using a 0.2mm shim if that helps.(I get my hardwear from a hardwear store, not a modeling store as they mostly have a larger selection of bits'n'bobs at a better price and also most nuts and bolts come in different materials or strengths.
Later dude.
Later dude.
#1617
Hello all.
Just want to share with you my last set up for the GXR28. After so many lost fights to it, now it is in its best shape ever!!!
#1619
Hello all. I hope this topic is kind of stuck because everybody is using the time to bash their cars!!
I have a question: since I don´t remember when, I am having some problem to make my inferno steers in a proper way in the corners. In the beggining I touhgt was the original servo. I replaced it by a fut. 3305. Then the tires, toe out, and for last, the diffs silicones. After all these it is a little better but not as much as I tought and want. The goal is to have the same cornering hability from my other car (xray xb808).
Along the years, aftet wrecking the original shocks I replaced them by the big bores from xray. Can this be the problem?
#1620
Hi Oskr, could be that you oil in the front diff is a tad to thick. or give it some more toe out. Nice to see your still using the Kypso mp7.5 though. Me to, still no major problems after how many years????
[8D]
[8D]
#1621
...after 5 year, Lez!!!!...and regarding the steering issue, I don´t think the oil thick is the issue. Basically I am using the same grades from my xray. But what I do saw these days, was the connecting link (from servo to servo-saver) was a little short. I lenghtened it and now is ok. And also, now the servo-saver arm is touching the steering plate when it is totally steered. But this is not a major issue.
Thakns for the reply, Lez. And I will keep seaching a solution.
#1622
Any one still using these a lot?I lent mine to a friend a few months back, it came back with a bent front shock shaft.
I haven't looked at it since. I might look at it at soon. It still runs but shock shafts are difficult to find.
#1623
ORIGINAL: R.lepecha
Lepecha, could be much worse than a bent shaft...so, you´re lucky.
#1624
Papa Oskr, lol. Got yourself a new hobby. My son is 21 today. Have fun and enjoy it now they she is still young.[8D]
I am still running the old mp7.5 and still no problems.:-) I got 4 of them now.lol thats how much I like em.
