2 speed
GA
RE: 2 speed
I am just guessing but with a 2 speed you do away with the center differential and if so this sure could create problems. Yes a 2 speed is not sanction race legal. I guess if all you do is bash on the street is might be OK.
WV
RE: 2 speed
he has an lx one, nice buggy but I bet he's not racing it . I dont know if it will fit or not but I would call OFNA directly and ask them 949-586-2910
RE: 2 speed
ofna told me it would fit but ill have to do away with the front break...but that shouldnt matter scence i wont have a cen diff right
RE: 2 speed
ORIGINAL: Dman250
if you dont have the center dif then ok but if you do youll spin out alot. i hit 2 mailboxes with my jato cuz it spun out when i hit the brakes (little bit was my fualt too). im guessing itll probly handle differently w/o the center diff (correct me if im wrong)
RE: 2 speed
ORIGINAL: Dman250
well i dunno if it will handle different becuase you still have the front and rear diff to control what wheel spins
but you cant control how much both front and both back wheels spin
RE: 2 speed
well with out the cent diff the same amout of power will go to all 4 wheels but as for turning and stuff there will still be the front and rear diff.
GA
RE: 2 speed
Whit out a center diff it will be much harder to keep the front wheels on the ground and if id does not have a slipper in the 2 speed running off road you are subject to tear up the drive train.
RE: 2 speed
Im putting the mbx ultra 2 speed in my ultra comp 2 the only thing i need is 2 8x19 mm bearings the stock bearings ar 7x19 and the ones that came in the kit are 8x16. and you can keep the frount brake youll have to move the lever to the top like the rear and use one servo push rod . or like the diagrame you can dubble up the disk in the rear.
