need help
need help
I broke the crank in my force 28 and bough a used engine with a good crank and bad sleeve but I cannot get the sleeve out of it to put mine in it. Any ideas on how to get it out. It will come up about 1/16 of an inch if that far but not any farther. I have even tried to grab that little bit with a vise and pull it out but it wont budge. Any way to get the rod and piston out with the sleeve in it.
Please help.
Please help.
RE: need help
With the head off, carefully rotate the crank so that the piston pushes the sleeve upwards, assuming there is still a bit of pinch. If this is what you have done to get the 1/16" out, try using a small flat head screw driver to gently, without scratching anything, pry the sleeve out. If this does not work, attempt to get it out by putting a zip-tie in the exhaust port then turning the crankshaft so that it pushes the sleeve out a bit more. Then use the screw driver again to try to get it where you can pull it out by hand. It may help to use a lubricant around the sleeve such as WD-40. Put a good amount around it then let it soak for a few minutes, then try the above methods. Good luck! =)
Edit: It is generally not possible to get the piston and rod out without removing the sleeve first. Sorry, missed this question.
