RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Axe Rossi Mamba .21 Break-in
Reply
Old 09-07-2008, 09:44 AM
golfita
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Axe Rossi Mamba .21 Break-in
Ok, I don't think I would be able to do that...
But now I have other problem: there was a lick on main needle valve and I wanted to tighten it a bit... but I broke it... Can anyoane tell me where can I buy one of this??? Because I can't find it!!! Or from what other engine will it fit??? I tried from an Axial .28 (my other engine) but it doesn't fit. Can it be from any other .21 engine???
Please help!
Thank you!
golfita is offline
Old 11-11-2008, 11:30 AM
Jeremy123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
From My experience you will need to replace the needle with another axe rossi. But you might be able to use a nova rossi needle.
Jeremy123 is offline
Old 11-26-2008, 11:08 PM
CRUZRC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i was about to buy The Mamba today but with all these problems that everyone had I am undecided!!!!Should I buy either a Ninja 21 JX consedering i already own a Vspec on my mbx5t prospec...or novarossi plus 21 5k? LMK any sugestions?
CRUZRC is offline
Old 11-27-2008, 04:17 PM
jonnymac
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got a mamba and its sweet as a nut. Not had a single problem.
Mind you thats not to say they don't have them, but i'm more than impressed with mine.
jonnymac is offline
Old 12-01-2008, 08:13 AM
razzor
razzor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have tuned a good few of these motors as well as sold many to guys and have yet to have any hassles.
worst issues i have had to date was a leaking front bearing and a worn rod on a Mamba.
Yes it is a schlep to runnin but once that is out of teh way they are awesome.
Guys are always comparing to OS Speeds and VZB's and RB's etc.... but yet myself and a few other guys can run with all of these motors with relative ease.
A buddy who drives a Losi8 runs a Axe Sport motorand two national events so far this year in the A and B mains.
So its all about process, taking teh time to runnin and heat cycle the motors and getting to understand how to tune them.
So many guys will always blame the product yet they are the problem.
If you have hassles tuning get a 2nd or 3rd opinion and when in doubt refer back to factory settings.
razzor is offline
Old 01-01-2009, 01:06 AM
  #31
Force4x4
Force4x4's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: rologti
Hi,
I send a mail to AXE ROSSI asking how the break in should be done...and they anwer me the following (it's true, the break in is really long!!!)
ENGINE BREAKING IN INSTRUCTIONS
AXE Rossi high performance engines must be correctly broken-in for maximum performance and life! Rushing this process can result in premature engine failure.
The carburetor of our AXE Engines is set at the factory at a rich setting for an easy start of the engine. The factory initial setting is the following: Main needle 3.5 turn open from closed position – Idle needle 2.5 turn open from closet position.
For a good break-in run the engine while the car is sitting off the ground at that rich setting for 3-4 tanks and then for the next 3-6 liters (1-1,5 gallons) run it on the ground at a low speed and gradually speed it up while you progress through each tank and leaning the high speed needle 1/8th of a turn at a time until it runs close to peak performance. Please don't take short cuts and run less tanks.
Make sure the engine stays within a reasonable temperature range 110-120°C (230-248°F) and make sure you see a good amount of blue smoke coming out of the exhaust throughout the throttle range to insure you are not running the engine overly lean. Do not run the engine too lean or you will over heat it and cause permanent damage to the internal components of the engine.
Remember always run the engine with a clean air filter.
FUEL
The fuel is very important for the run of the engine.
The correct fuel needs to contain:
NITRO 20-30%
Synthetic Oil 6-8%
Castor Oil 2-3%
Axe Rossi recommends the following Fuel brands:
AXE by ROGA
ROGA
BYRON
O’DONNELL
I haven't been on here in quite awhile so I thought I'd stop by and update everyone since I started the conversation, I finally got my Mamba running right following the above suggestions from Axe that rologti posted and completed the break-in (which is insanely long) and my Mamba has been running like a raped ape ever since, I still prefer my V-spec but the Mamba is an excellent engine, just a pain to break-in.
Force4x4 is offline
Old 01-01-2009, 01:42 PM
  #32
JBthatsME
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am trying to find an motor that runs for along time, last along time and hangs with the higher end motors. I know most guys here in houston are using OS but I have heard good things about the way the Italian's make their motors. Is Italian made the way???? It says the Axe has 3.1hp, does this mean its going to be all low end or is it smooth all the way to the top?
I cannot decide on the following engines?????
-Axe Rossi MAMBA X1 Evolution
-Go Technology .21 7-Port
-O.S. Max .21 VZ-B V-Spec-T
JBthatsME is offline
Old 02-23-2009, 10:42 PM
  #33
RC-Captain
RC-Captain's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just bought the AXE VP MOD COBRA, can some body suggest a clutch for the engine. I looked at the Fioroni and the werks but for the price wasn't sure if there was some just as good for less.
RC-Captain is offline
Old 12-30-2009, 12:07 AM
  #34
Falconeer
Falconeer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WOW! I just started the engine for the first time yesterday evening, and I just fell in love with it!
I did have an issue, but that was my fault, not the engine's. I had the clutch too tight where the fly-wheel would just jam and I kept thinking that it was the engine pinch.
THIS ENGINE IS AMAZING.
First touch on the starter box (OFNA) and it was running. Factory settings were just right, but I did richen it a bit cause this is a hot country.
This thing idles for ever and has great acceleration even when rich.
Yes the break in is a long process (I am following the one in this post), but wife and I are enjoying it.
Overall, the Axe Rossi MAMBA X1 Evolution engine is THE BEST I've owned so far.
Falconeer is offline
Reply
Display Modes
