Hyper 7 suspension question
My hyper 7 is brand new outta tha box but it seems to me that the front suspension sags a little to much. The chassis does not touch the ground while idle but there is only about 3/4-1 inch clearance while just setting still. I wasnt sure if this was normal or if I need to increase the shock oil weight. It doesnt seem that the shocks have leaked at all. Is this normal?
RE: Hyper 7 suspension question
that is perfectly normal dude you dont hve to change the shock oil weight. what you should do is put some spacers inbetween the shock and the spring this will raise your car for more clearance
Banned
If it's an RTR you'll need to sort out the setup, the shocks and diffs will NOT be ready for any serious action. Try a search for the topics you want info about, they are all here.
