problems with hurricane xp
if my hurricanes wheels twitch at a distance of five feet, and the throttle isn't working, is it the crystal. if so can it be fixed or replaced without replacing the entire controller? where is the crystal and what does it look like[&o]
Banned
RE: problems with hurricane xp
ORIGINAL: Harker1
NY
If you are using the factory AM radio, then it means that it may take off at top speed and won't stop until it crashes into something unmoveable. I know because that is exactly what happend to mine on my first run with it. I would change the transmitter radio to something better and you shouldn't have that problem anymore unless your batteries in either the radio or battery pack are dead.
yep ditch all of the radio gear. Buy once and get something that will last for a long, long time , like a Spektrum DX2.0 or 3.0. I had a runaway with the original radio gear straight into a tree and then down into a creek. After all sorts of stuffing around to find out what the problem was, I removed it and installed a Spektrum DX3.0. and a 6v NiMh hump pack for the Rx. Never had a hint of a problem from then on. Spektrum also has a fail safe built in and comes with decent servos., so there is another saving. Have a look on youtube for my radio glitching problems with my bazooka/hurricane.
Also be prepared to change your servos to decents ones, as the stock ones dont last long.
