Brake Pads Assembly
Location: San Diego but living in Dubai, UNITED ARAB EMIRATE
Brake Pads Assembly
errrrgghhhhh.....dduuuuuhhhhh.....mmmmmmmm....[:@]
OK, how do i attach the actual brake pad liner to the metal pads? Book says to use "rubber" glue. Can i use CA glue or tire glue for this?
As usual, thanks a ton.
RE: Brake Pads Assembly
Integra, running fiber glass brake discs on the Jammin, what you recommend for the MP7.5? (other than to sell the kyosho and upgrade)
MB, CANADA
ORIGINAL: tommygun32
same...get some more fiber disc's and ur good to go....metal/pads dosent cut it imo...they fade out fast from what ive seen.
