s5 l2g break in
My Feedback: (8)
s5 l2g break in
every break in iv done was tires off the ground 4 tanks then light throttle on the track and lean it out. a lot of my buddys have used the heat cycle. i only know of a few guys running rb and they are hours away. so some of yall that have had good luck with rb engines what did you use?
WI
RE: s5 l2g break in
I used the heat cycle but it took at least a gallon before my S3 L2G started running consistant. It was one of the most difficult break ins I've ever done. Good engine, just a pain to break in.
