Truggy Tires on Buggy?
I have a OFNA 9.5 and I have worn out the tires. I'm thinking of buying wider truggy style wheels on it. Has anyone tried this?
I was thinking of getting the same diameter wheel, but I am also entertaining the idea of getting wheels with a larger diameter to get a little more clearance. Has anyone tried that?
MB, CANADA
RE: Truggy Tires on Buggy?
ORIGINAL: Ecas32
i guess it would be possible, but you'd better but a larger clutch bell on it so it wont be as hard on the engine
ORIGINAL: INTEGRA
FYI You gear down if the load is too much...Not gear up.
ORIGINAL: Ecas32
so it is "gearing down".... you know for low end
"gearing up" is top end
CA
ORIGINAL: Ecas32
a larger clutch bell gives you more acceleration.
ORIGINAL: INTEGRA
ORIGINAL: Ecas32
MB, CANADA
ORIGINAL: Ecas32
ORIGINAL: INTEGRA
ORIGINAL: Ecas32
MB, CANADA
ORIGINAL: brushless6s
You will also need to run your engine slightly rich to keep temps down.
ORIGINAL: INTEGRA
Also NO.....the sheer gearing wall you would put up in front of the motor would be too great and cause excessive wear and tear on the motor and clutching system
TN
Putting big tires on without a lot of other mods is a bad idea, I tried it awhile back. The buggy ran very hot and was super slow. Get a truggy or a conversion kit.
NJ
all in all its a bad idea.and personally i think it would look stupid.just my opinion though,you will encounter problems as well just as everyone said.
My Feedback: (31)
KY
I tried some maxx wheels and tires on my buggy i had and it hated them with the stock gearing. I could have only went 1 tooth smaller on the bell, and i know that wouldnt be nearly enough. I only ran my buggy 1/4 tank before i decided it was going to melt my clutch if i didnt stop.
Eric
Eric
If you cant get a final gear ratio of 15.5/1 (often requires a larger spur gear), dont bother bolting truggy wheels and tires onto an 1/8th scale buggy chassis.
