Losi Clutch in Hyper 8.5
MB, CANADA
RE: Losi Clutch in Hyper 8.5
ORIGINAL: haasjj
Will a Losi 4 shoe clutch work in a Hyper 8.5. I cant see why it would not but just wanted to make sure before I buy one.
problem is the losi clutch requires you to use a Losi bell...which are A lot Taller then a standard Ofna/Mugen bell....therefor you would have to be able to shift the motor back a couple mm to make everything line up....the thing with the losi and the adjustable mounts for them is the fact you can switch from the forward position to the rear position and run w/e clutch you want....your Hyper will not have that option....therefor you will run into problems trying to get it mounted....I meant to try and see what car's i could rig the losi system on...but never got around to it.
