Need Help, What Model Ofna Buggy Is This??
CA
I bought this buggy used about 6 years ago, I think it is about 10 years old. All that I know it it's a Ofna. I need some parts but I have no idea what model it is, so I am having a hard time trying to figure out what parts to order, if they are even still avalible.
FL
RE: Need Help, What Model Ofna Buggy Is This??
Looks like an old version of the lx1. I don't know if any of the new version parts will fit. I would check www.Nitrohouse.com or Call Ofna helpdesk Tech Support / Cust Service: 949-586-2910
CA
I don't know about calling the help desk without knowing which model it is. I will search nitro house for lx1 parts and see if they look close.
FL
The new one looks the same but a different color. If you send a picture to ofna they can tell you for sure but I am 65% sure its a old LX1.
MI
looks similar to an older model buggy i looked up awhile back. Try OFNA Ultra GT LX. Found out thats what mine is. I copied lots of part numbers that might help if you find out its the same. Good luck with it either way.
CA
I think that you solved it with the Ultra GT LX, the pic looks like it matches other than the front upper a-arms. If you can give me some part number that would be great.
CA
I down loaded the manual from Ofna's site so I do not need part numbers. The Ultra-MBX manual matches perfectly, so I guess I have a MBX. Tower actually carries the parts for it. I cannot believe it, anyway thanks to those who got me on the right path to figure out what it is.
