Stick pack connector confusion...
I have a few noob questions
1. I need a 5 battery stick pack for my Hyper ST...is there a maximum mAh i can use? and how long will a 1100mAh last? Apart from 6V and JST style connector...is there anything else I need to know?
2. What orientation do you use when connecting the stick pack to the switch/receiver? The JST plug on my old stick pack doesn't have an orientation...do I just match black wire with black wire and red with red?
3. Finally...is it possible to use a stick pack with a white connector on it? and then use a white to JST convertor wire? (i have one from my stick pack charger)
RE: Stick pack connector confusion...
i have the 4 x AA holder as well...but how can i attach it to the Hyper ST? because the stock body only allows a 5 x 1.5V stick pack...
would the 4 x AA do the same thing? and last as long if they were the same total mAh?
