Diff spool, use for off-road racing? or no?
NC
So Losi is releasing a spool insert for the 8ight models. The site says great for oval racing, but what about off-road racing? Would this be a bad idea? I do understand that this mod will put all wheels with power at one time. It says for better acceleration too, but im wondering if it will spell disaster for off-roading??
any thoughts?
any thoughts?
RE: Diff spool, use for off-road racing? or no?
So essentially you would have full posi-traction? If so, you'll have no slip when turning, the right tires will turn at the same speed as the left tires. While on oval with wider, more consistent turns it could work, on an off-road track the turns are tighter. If anything, maybe put the spool in the rear diff, and keep the front without.
NC
Oops, I forgot to mention that this is a center diff spool. So I guess all 4 wheels pull at the same time....? Right?
MA
ORIGINAL: big_poppa49
