Starter box motor help
CA
Sorry guys if I posted in the wrong area. Couldn't find info on where to post a stater box question. Anyhow my box isn't worker. I put a new spin wheel in and I wondered why it wouldn't spend when I was done. A buddy noticed my bottom screw to hold the mount down on the bottom was long and hitting the spur motor cause it not to spin. I corrected the problem and rescrewed in a different slot. I test it and the inside spring the gets pushed down to make the wheel spin gave a spark. Nothing is now working. The battery check light says full. I'm trying to figure out if he motors blew or is there a fuse somewhere? Wouldn't one motor bllow and not both at the same time? If they blew what new motors should I use that's a goo cheap price? Thansk
