SI3 Stained
RE: SI3 Stained
Logan wanted purple but i told him his is purple and mine will be orange
if Lowes had a pint size tintable stain it would have been two colors but they only have QTs 11.00 ea and i barley used any
RE: SI3 Stained
ORIGINAL: 71dartswinger
Just a recommendation - if you are using a nitro engine on that boat, I'd let the finish set (final coat) for about 21-30 days before getting fuel on it. Varnish and Polyurethane take several weeks to fully cure - in that time some solvents can eat into it and soften/cloud it.
I used minwax duraseal stain on my Kami - Its what we use at work. I used 2pts colonial maple to 1pt fruitwood.
RE: SI3 Stained
it isminwax stain tinted orange from lowes it can be tinted just about any color you want
and i have to sand and give at least 3 more coats before it is like glass
RE: SI3 Stained
RE: SI3 Stained
i did not test but it is high gloss marine spar varnish
i will test this week will put stir stick into fuel and see what happens
RE: SI3 Stained
RE: SI3 Stained
I recently built a small table/bench set for my kids. Stained with Minwax water based and coated with three sprayed on layers of automotive 2 part clearcoat. Amazing finish!!! Wish I could afford to finish all my woodcraft with auto clearcoat. So much better in my opinion than standard polyurethane. And you KNOW it's fuel proof!
RE: SI3 Stained
ORIGINAL: Dreamin Hemi
RE: SI3 Stained
stuck stir stick with stain and one dip into varnish into 15% fuel and it did not get soft or stickey so i guess fuel will not harm
it is cabott marine high gloss spar varnish from Lowes
two more coats on top and 4 on bottom
final coat will be sanded with my model finishing kit 3600,4000,6000,8000,12,000 then wax
steve
steve
RE: SI3 Stained
steve
steve
