New Gas Flatty Build.
Have beenhaving a ball runningmy flatty down the sandflats but wanted to build myself abetter looking airboat.
45"long x 17"ride surface, drop deck with a cutback nose. More of an airfoil profile, Cad up some plansand away we go!
Some pics of the build so far.
RE: New Gas Flatty Build.
Drop deck, flat bottom(runners)
Checking the radio box setup/fitting before glassing the inside.
The reciever and powerpack have thier own sealed cutouts to keep it all nice and neat.
MN
Thats what I meant to say curious how the runners will work - it will probably drive more like a tunnel or hydro than a slider. Air rudders or water?
I made a tunnel with short sponsons and couldnt get it to turn with air rudders.
Hull interior with resin coat and 1" tape on all seams/joins.
Now can glue in the radio box shelf and engine support plate.
Made the prop adapter today in at the hanger, the front plate sleeves over the centre shaft and has 4 press fit monel steel pins which pass through the holes already in the prop and locate in the backing plate part of the adapter. Also put a recessed grub screw in the adapter as this one is mounted on the pull start side of the 30cc POPE so I can run it in Pusher mode with normal Puller props. :wink:
