4th boat build. Mini-Kaze Stepboat
#76
RE: 4th boat build. Mini-Kaze Stepboat
Hey Tim,
Nice looking boat you have going there. You're so lucky to have a body of water with out a crowd around.
Did I see this right ?, in the second video...around .04 seconds in, after you placed the boat in the water,
I thought I seen a fish porpoise up at the right hand rear of the boat...may have been a leaf ???
#77
ORIGINAL: oldfrog
Hey Tim,
Hey Tim,
The last time I watched that video I saw that too. It was an oil droplet from the tuned pipe. The pipe hangs off the back of the boat a 4-5 inches and at slow speeds you see all kinds of little "fish eye" spots. Just castor oil. The only fish in the pond are big bullheads and some small mud minnows. Haven't seen any turtles or frogs yet.
#78
Thanks for the picture of rudder. I haven't been myself since the first of the year since they fiund i had esophaus cancer and have had 2 chemo trips and tomorrow i have a chemo bag put on for 5 1/2 weeks and radiation every 5 days for 5 1/2 weeks. Sure takes the wind out of my sails. Chances are 1 out 10,, but never know. No crying towels but i'll make it. No repies please.-BTW i'll make a rudder close to what you have done.
#79
ORIGINAL: Mikeup
I wont linger on the subject, but I do wish you the best of luck in your treatment.
On the rudder... If the rudder strut was made of aluminum, it would be heavier and allow for a spring to be used to hold the rudder down (running through the body of the strut), whereas I dont have a mill so I used wood which is much easier to work with and the nylon screw works very very well. I ran 7-8 tanks of fuel through the boat on the water and havent had the breakaway kick in yet. I think if I hit a turtle close to the surface, the boat would flip before it would hit the breakaway. It does not ride very deep at all.
#80
MN
Looks like she runs good there Tim, very stable and controlled with nice turning, no pourposing, Just need to get that motor broke in and...a video camera that focuses ...And LET HER RIP.
I had the best intentions of getting out this weekend - but without a kayak or raft - Its was a little... risky - being my boat has not proven itself 100% reliable.
#81
I have to shim the engine mount to get the prop angle better. At full power it's got a dig up front I can't get rid of. I'll do those mods this afternoon so I can test on Wednesday. I took the day off since its my birthday.
All I have to take videos is a Nikon cool pix. It's not a good video camera.
The boat handles like a dream. Needs to lose weight and if need be, my .46.
#83
ORIGINAL: dadkins
Dont you be switchin motors before we race - looks like I MIGHT have a chance now.
#84
I think I have determined my slight plowing problem. When I originally drew up the plans for this thing, I had the engine mount square to the rear deck and the rear deck was supposed to be parallel to the water's surface. Somehow, and I dont know exactly how it happened, but the prop angle is 3.5° above square. The other day I shimmed the engine up using .060" washers, and tried two on each side giving .120" of height in the back. Turns out 3 more .060" washers would have brought it level and probably ran better. So I'll cut some shims tomorrow, maybe 2 sets.. 1 set to make the engine level, and 1 set raising an additional 1-2° just for good measure. Hopefully this does the trick and allows a straight line drag race with some real speed.. I just will not settle for 25.6mph. I gotta get to at least 30mph. Then it would be as fast as the big kamikaze with the K&B .65 and 13x5APC.
Dave: to be fair, I'll leave the tuned pipe un-tuned for the race...
#85
MN
Hiya Tim. Happy Birthday !
Hope you get some good runs in today - I still have yet to put mine on the water - havn't even floated it in the bathtub! Dont even know if it floats! I'm sure it does Its made of foam...
I was thinking about bringing it to work and running during my lunch hour at Busch lake - but I have been riding my bike lately(motorcycle).
And then theres the lack of rescue boat + chilly water.... may have to buzz the shoreline ???
I saw 10' plastic kayak at Menards for like $300 - might serve dual purpose recreation and airboat rescue.red,blue,green or yellow.
We are going to have to start planning for the big race before you get that thing too dialed in.
When? Where?
Saturdays work best - then Sundays. Let me know.
When? Where?
#86
ORIGINAL: dadkins
When? Where?
When? Where?
I'll check with the Mrs. and see if there is anything planned next weekend. I will try to sneak out early today yet and test it out. I just put a coat of sealer on my motor mount shims, so as soon as they're dry, I can cut new screws and get it ready again.
#87
MN
Next weekend may not be that awesome for me as it is Easter the 8th and we have 16 people coming over for brunch, I'm not saying it won't work, it just kind of depends on how organized we are.
14th looks good. ?
14th looks good. ?
#88
MN
I have a Neighbor/friend that has a lake house right by me and speedboats are allowed - and a couple swim platforms we could race around.
#89
We can shoot for the 14th for now, that's cool. Unless something comes up or cancels. I have a few more mods to make to the boat anyway. This pond you speak of... I can run my wet rudder, right? its not too weedy? I didnt make any air rudders for it and probably wont either.
Tested it with the prop angle changed and it's still not quite perfect. Still digging in a little when running WOT in a straight. Changed a few other things and didnt make it any better, so I think I need a smaller prop with more pitch to get a few more rpm. Peaked out I'm getting about 16,000 on a 9x5. I can run too much nitro in my fuel because the engine isnt set up for more than 5% really. I tried 7% nitro and didnt see much of a difference in top end power, just made the midrange a little lean.
grr.. I'll keep messing with it.
#91
MN
Not much at all - Family has other commitments - This weekend might work good - do you have my cell # ? I think you do - look under RC Dave
Shoot me a text and well see if we can get out and do some racin !
#92
MN
This time of year the lake is really clear - I actually have 3 choice spots within 2 miles of my house with 2 being electric motors only
but I have NEVER taken any heat over running at either of them.
#93
ORIGINAL: dadkins
#94
MN
Tomorrow works good for me - Wife works all day -I do have a company party at 7 - so I would probably have to wrap it up around 5ish - go home and wash the nitro off.
#95
Since I've been in the process of testing and debugging my Kamikaze stepboat, I decided to make a (sloppy) tray that can be adjusted and/or removed to hold the GPS. I made a few mods to the radio box to lighten it. I shaved about .8oz off the bow's weight, which isnt much. The boat balances very nicely with the GPS on-board, but I'll have to see how well the mods work today. Going out to run her today against Dadkins' custom built .40 flat bottom boat... We'll see what happens there...
#97
MN
I went pretty good - we both have a bit of dialing in to do. To sum it up Mine is too loose and somewhat uncontrolled - and the Mini Kazi is too tight - just pinned to the water with ultimate control. We werent really able to race as my boat was kinda hard to control, and the bouys that were there -one was a boat bumper that flipped my boat and would surely take tims rudder out.This was actually my maiden on water and it has some sorting out to do.I do have some good video -but I have never tried to uplode to Youtube before.
I may give that a try at home tonight.
#98
You'll have to upload what you have, Dave. My memory card didn't have any videos on it.
I bought a pair of hitec HS82mg servos which I hope is enough torque. Will find out. This will save me 2.6oz minimum.
#99
MN
Hey Tim,
I was trying to upload the vids to my computer last night and it looks like I had my camera set up wrong - The good News - all the videos are there - the bad news - they recorded in the internal built in memory - the other bad news - I havn't had the greatest success uploading to youtube in the past - It has been a while and I will try again tonight.
#100
Well, after our run on Saturday, I decided a few more mods were necessary. I picked up a pair of hitec 82mg servos which are much lighter than the 645mg servos I have in it now. The servo tray originally made for the boat weighed just a smudge over 6oz with all mounting screws. My new tray with the lighter servos is coming in at 3.75oz. A good improvement in frontal weight, so hopefully this will help get the minikaze moving. New pics will come later. The new servos have less torque, but are significantly faster. Hopefully this mod alone does the trick.
