Go Back  RCU Forums > RC Boats > RC Airboats
Reload this Page >
Weed Wacker Servo
RC Airboats Discuss R/C Airboats here!
Weed Wacker Servo
Old 03-04-2012, 01:22 PM
oldfrog
Default Weed Wacker Servo
What type of servos are people using with weed wacker engines ?
I'm goofing around with a Ryobi/Homelite 30cc leaf blower engine
with an electric start. The throttle return spring sure is a stiff one.
Old 03-04-2012, 02:18 PM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Default RE: Weed Wacker Servo
ORIGINAL: oldfrog
You would need a 1/4 scale servo for a gas engine. Get ready to shell out some $$$... This is one of the reasons I haven't gone gas powered.
I too have a homelite 30cc sitting here, but no real intention of putting it on an airboat.
Old 03-04-2012, 05:01 PM
Lester Burch
Lester Burch's Avatar
The servo that we uses is a HItec HS-645MG about $32.00.
Torque: 106.93 oz-in at 4.8V 133.31 oz-in at 6.0V
This is a good servo for the rudders to and there is a waterproof one now.
Old 03-04-2012, 05:24 PM
1QwkSport2.5r
ORIGINAL: Lester Burch
I use these servos with my glow powered boats, but depending on the weight and size of the engine, I would use a higher torque servo for the rudders at the least. Hitec has a high voltage servo that will handle 7.4v. I think it puts out somewhere around 300oz/in or more at 7.4v.
I should have rephrased what I said before, I would use a standard sized high-torque servo for the throttle but 1/4 scale for the rudders if using air rudders. Wet rudders could probably get away with a standard size high-torque servo like the 645MG.
Old 03-04-2012, 06:05 PM
Lester Burch
I have used the ΒΌ scale servos on our !/4 scale Airboats for years and they work good but they have been overkill on some of the Airboats and the 645 has been a good way to go.
If you have the room the Hobbico CS- 80 works good for the rudders.
Thats All Folks
Old 03-04-2012, 09:41 PM
rangerfredbob
My Feedback: (13)
you only need a standard servo for throttle even if the return spring is left on (it should be left on)
I've been using a standard size high torque on my gas airboat, I think it's in the 120 or so ozin, need to get that thing back on the water...
Old 03-05-2012, 07:16 AM
dadkins
Standard servo for the throttle, 1/4 scale for the rudders, That would be the only way I would feel safe.
