If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 3 of 3
Thread: New Project
  1. #1
    Join Date
    Feb 2011
    Muskegon, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    New Project
    Hello everyone,
    Well, here comes another airboat (?) project. This one will be based on this Ryobi 30cc engine. It's converted
    from a Ryobi backpack leaf blower. The engine went from 5800 RPM to 7200 RPM just by eliminating the stock
    muffler. The new exhaust plumbing is fabricated from aluminum and stainless seamless tubing. The oil mix
    called for 50:1, but I'm running 32:1 for better lubrication. The 32:1 mix gives just a slight smoke trial. I milled
    off the mixture screw walls and cut slots in the mixture screw heads to facilitate the mixture settings. By the
    way, I did run the carburetor mounted up-side down and it ran just fine that way too, but I turned it right-side
    up afterwards. I removed the crank and cut 1.5 inches from it and rethreaded it with 3/8-24 thread. It also had
    an electric start mounted to the back but it looked crazy on there so I fabricated an old timey pulley for it and
    it works great...some of you will remember this type of pull-rope system. The engine is running a 16x8 prop
    at this time.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1745604   Click image for larger version.
ID:	1745605   Click image for larger version.
ID:	1745606   Click image for larger version.
ID:	1745607   Click image for larger version.
ID:	1745609   Click image for larger version.
  2. #2
    Selph-Inflicted's Avatar
    Join Date
    Mar 2004
    Okeechobee, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: New Project
    All its lacking is.....a boat.
    Owner, \"Selph-Inflicted\" RC Airboats & RC Airboat World
    RCAA (Radio Controlled Airboat Association)
  3. #3
    Join Date
    Nov 2006
    Texas TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: New Project
    I really like what you have done with that engine! Clean, well engineered, very professional looking. So many of these conversions look.....much less finished. Good job!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
