I have some Electric Swamp Buggy Questions.
I'm getting ready to start a new Swamp Buggy project. I already have an engine, ESC, and a LiPo battery. Which seem to work wonderfully together. I'll leave the Specs at the bottom of this post. So my questions are
How large should the hull be (length and width) and basic shape in order to allow for sharp turns at descent speeds without a 100% flip chance. (Calm water of course).
Where should the prop/engine be in relation to the boat itself? Should the prop be spinning in the middle of the boat of as far back as I can get it? Engine pushing or pulling? Things like this.
I would like to make this boat out of 2 inch House Insulation Styrofoam which I already have easily on hand. So the question is how do I fiberglass the styrofoam without “melting” it or adding to much more weight?
I have a few pictures ill add to show basic things I have played with. Any help will be greatly appreciated!!!!!!
Engine – Electrifly Rimfire .15 (35-36-1200kV)
ESC - Electrifly Silver Series ESC 5V/2A
Battery – 1000mAh 25C 11.1V 3cell LiPo
2. Put the motor in the back like you see on most airboats. This helps to keep water out of the prop when running.
3. I built a lot of FE boats out of 2" Styrofoam. Cover it with 1/2 to 1 oz cloth, use thinned epoxy to keep from melting the foam. Thin the epoxy with about 25% isopropyl alcohol.
Do I use 25% isopropyl alcohol and if so at what ratio of alcohol to epoxy do I use, or do I use the normal % alcohol and water the epoxy down by 25%?
Thank you for the Help!
This is my brothers YouTube channel that has the 3 videos (their the only videos he has on his account)
Videos - http://www.youtube.com/user/Odin5117?feature=g-user-u
Engine itself - http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLWU3
I'll aslo post a few pictures of what I put togeather last night! I couldn't wait for the real hull to be done so I glued this togeather! Something for just playen around in the house as I wait!
Thanks for all the help so far!
These are the steps I know for doing this.
1. sand area to be glassed
2. Cut and fit the fiberglass.
3. Mix the 1/3 epoxy 1/3 hardener 1/3 rubbing alcohol.
4.. Place the epoxy mix over the fiberglass and "paint" it into the area to be glassed untill all areas are clear.
5. Wait until hardend and cut off extra glass and sand.
6. Paint
As far as Your front angle - looks a little steep - I would do a bit more sanding and make that trasition smoother-longer.
Looks Good!
