depron foam repair
depron foam repair
Hey all another aero drifter update
If anyone took a look at my videos you saw how tis lightweight airboat will go anywhere drifting this on asphalt
is fun but the bottom gets nice dings gouges and scraps, without the packing tape i would have ground through the hull...
To fix depron i boiled water and ran the hull over the steam 99 percent of the rash was gone.
So steam is the key for this foam
MN
RE: depron foam repair
Interesting. Ya I used to build foam only hulls for my little .15 - water only - but eventually they would get all kinds of dings and really didn't last very long - but with that minimal weight they had fantastic hole shot.
ORIGINAL: dadkins
Dave - we will have to attempt a rematch on the boat drag race this coming season. I got another new engine that has me all excited.
p.s. I did a job on the same lake your buddy has his cabin on. Drove past it and recognized the house. We may need your kayak again, too.
MN
Hiya Tim,
I ended up selling my OS.15 as I could never get a consistent needle on it - It had this little drum you turn on the carb and was really hard and dangerous to tune while running. I have a throttled .049 and some micro servos off a helicoper and a 1' hunk of foam -that might be a nice little build.
Ya I took my boat out Saturday on the snow and... had a hard time going slow enough to not flip it...I think I stripped my steering servo gear on one particulary gnarly blow over. Might be time to put the front wing on and sacrifice a little speed.
Cold weather brings out the best in that little Thunder Tiger.
ORIGINAL: 1QwkSport2.5r
I've been reading this thread, just in case I need to repair foam. I now have a little .10 engine now so a little foamy is in order...
ORIGINAL: dadkins
Not all foam responds the same way to steam as depron does.
