Go Back  RCU Forums > RC Boats > RC Airboats
Reload this Page >
prop cage materials
RC Airboats Discuss R/C Airboats here!
prop cage materials
Old 08-11-2013, 05:06 PM
yellowufo
Default prop cage materials
Hey all im looking for some light weight tubing to make a prop cage weight IS an issue my last hoop to protect a bigger prop i installed was made from old 22cal cleaning rods and they worked great.. i would like something i can solder to....any ideas?????
Thanks Jim...
Old 08-11-2013, 07:05 PM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Thanks Jim...
I dont know if it can be soldered to or not, but I know NAPA auto parts used to carry brake line in long chunks that could be bent easily. The smaller the tubing the easier it is to bend. BUT like I said, I dont know if solder will stick, or if a good solder is going to hold it unless you spend the big $$$ and get some silver solder and silver solder flux. If you have access to a MAPP gas torch, you could probably use some Brazing rod and Braze the joints instead of soldering. It will be much stronger and last a lot longer. This would be worth the $50 for the torch kit IMO.
Personally, I think prop cages are overrated though.. =D
Old 08-15-2013, 07:06 AM
yellowufo
Right now i have a loop roll bar like the old sprint cars. Without it the whole tower gets ripped off in a flip lol.. being foam repair is easy but i hate to trash a prop
Old 08-15-2013, 09:05 AM
1QwkSport2.5r
What kind of props are you using that get trashed from a flip? I've never broken a prop from flipping. My hulls are wood and quite sturdy though. How are you mounting the engine/motor mount to the hull?
As for the prop cage, I'd invest in a tubing cutter and get the longest 1/4" O.D brake lines you can and cut/bend as needed. Braze the joints and be on your way. You could use solid steel wire as well, but I think the tubing will be stronger.
Old 08-15-2013, 09:09 AM
yellowufo
My rig can run on pavement it is foam very light
Old 08-15-2013, 05:52 PM
1QwkSport2.5r
You shouldn't flip your boat on dry ground..
Old 08-15-2013, 06:03 PM
yellowufo
Lol
Old 08-15-2013, 06:11 PM
yellowufo
Check out model aeros surface drifter.....
