Go Back  RCU Forums > RC Boats > RC Airboats
Reload this Page >
In-Line Twin projects
RC Airboats Discuss R/C Airboats here!
Old 08-30-2013, 02:42 AM
Jeremy_H
Jeremy_H's Avatar
Default In-Line Twin projects
Following on from my introduction post: http://www.rcuniverse.com/forum/rc-a...ing-hello.html I'll put the progress on these boats here. The idea is to build in line twin airboats, two the same, one electric and one IC.
After some time spent fiddling with fuel arrangement I needed to try the setup out for real, so a quick build is needed to get the engines on the water.
So, with the thought of using a boogie board being dashed by no one in the family being able to tell me where ours have got to yesterday I put this together:
This also helped with a new material I'm trying for modelling, PVC Foam board (i'll report fully on my thoughts on this material when I've done some more). I've gone too heavy for this test bed boat as it will have a future as a test bed for a petrol engine I've a hankering to have a go at. The material is recycling old sign boards with zero outlay, which appeals to me on a throwaway boat. Some sign vinyl roll ends gave a quick fuel proof finish.
Next I'll work on the engine and rudder mounts.
Name:	TEST AIRBOAT 1.jpg
ID:	1914712   Click image for larger version
Name:	TEST AIRBOAT 2.jpg
ID:	1914713   Click image for larger version
Name:	TEST AIRBOAT 3.jpg
Last edited by Jeremy_H; 08-31-2013 at 05:32 PM. Reason: link to OP inserted so people know what I'm heading for
Old 08-30-2013, 02:56 PM
1QwkSport2.5r
1QwkSport2.5r's Avatar
I'll be watching your progress for sure. Good luck on the build!
Old 08-30-2013, 04:37 PM
Jeremy_H
Jeremy_H's Avatar
Thanks .
Did most of the engine mount for the trial boat today, milled from a 5mm thick 'T' section Aluminium extrusion, with recesses on each side so the engines are on the same centreline. Glad I've made it as the final mount will be similar and a couple of things came to light. How to sort the throttle linkages (was hoping to mount the servo in the central cutout), and need to divert the exhaust on the aft engine (maybe custom exhausts for both, but certainly an elbow needed).
ID:	1914895   Click image for larger version
Name:	Engines Mounted.jpg
Old 08-30-2013, 05:09 PM
Altered1
Just be careful when tuning that twin setup. a miss placed hand.......... great idea though.
Looks like you've got some great tools... A milled mount !
Old 08-30-2013, 05:36 PM
1QwkSport2.5r
How thick is the mount where the engines actually bolt on? I used 1/16" aluminum L channel on my little SI3 with a Jett .35. The L channel cracked and broke within 6 tanks of fuel. Double the engines, double the vibrations.... Be careful and keep an eye on it if its less than 1/8" thick. And +1 in watching the fingers!
Old 08-30-2013, 06:54 PM
yellowufo
I think the mount needs a few gussets to (strong) it up a bit
Old 08-31-2013, 01:07 AM
Jeremy_H
Jeremy_H's Avatar
I made a bench mount for the engines which spaced them about twice as far apart as this, and became conscious of the higher risks with that one, let alone this arrangement. On all my previous Airboats I've had open props, but this one will have shrouds (I've got my eye on a couple of my good lady wife's mixing bowls to use the rim, tough plastic and perfect shape ), even so, I've decided that tuning will be with one engine running only, and I'll extend the needle valves if it helps.
I have a couple of small Chinese machines, a modified Mini MIll and an 8x16 lathe. I've had to do some major work to sort their problems out and make them more usable, a belt drive conversion and digital readout setup for the mill, and a complete drive train replacement for the lathe in the form of an inverter and three phase motor. The mechanics on these machines is excellent value for money, the electrics and drives on both were rubbish:
I share the concerns over the mount's strength. A 1/16th mount is a little under 1.6mm thick, this one is 2.5mm under the engine. I've used 3mm before in plate form with a .40 OK, but the stresses on this one are on on one side, plus with two engine vibration is going to be complex with two sources, i.e. not just twice the source, but the two could cause all manner of weird stresses as vibrations fight each other. So, as this is a boat to check over such things I'll keep a close eye on it. But, I think I'm already comitted to installing webs, or gussets, to the underside of each engine, one on each at least, probably lightened 5mm aluminium so that the engine bolts fix them to the vertcal web, and through bolted to the horizontal one. An alternative is to start with thicker extrusions, this is what I have at the moment. One other factor is the servo, that's a hostile place to be situated.
ID:	1915026   Click image for larger version
ID:	1915027   Click image for larger version
Old 08-31-2013, 04:13 AM
Altered1
I really want a setup like that, but just cant justify, nor afford it
I'd suggest a bell crank arrangement for your throttles.... put the servo somewhere safer
Old 08-31-2013, 06:19 AM
Jeremy_H
Jeremy_H's Avatar
I'm office bound these days, but a Fitter/Turner by trade, so as I like hobbies to support themselves I started machining bits for folk as another hobby of mine is Airgunning, ending up making parts for Target Rifles etc, the machine paid for themselves pretty quickly fortunately.
I'll take that advice on the servo. I'll will see if there's a way of using bellcranks as you suggest.
I'll be running the mount later, I'll see if a vid can be done
Old 08-31-2013, 07:55 AM
Mike2735
I will definitely be watching your progress.
Old 08-31-2013, 04:45 PM
Jeremy_H
Jeremy_H's Avatar
DIverted a little by pushing the test boat build forward, I really wanted RC control over those engines so needed to move the servo mounting along, so tasks grew . For now I've rigged the servo as intended, just the linkages to put in, mounted the tanks in the position they will be on the target boat, and stole a sandwich box from the kitchen for the radio gear.
It's quite compact in the engine area, but will have to be smaller still for the final boat: The mount is 2mm Dural, it takes some effort to flex it by hand, only running will show if it's stiff enough. If not, some cross bracing underneath will sort it. A couple more fixing screws to the hull needed.
The exhaust direction issue has been resolved using a silicone elbow from an R/C car for now, I'll rotate the silencer end towards the centre more to protect the deck before use: The vertical aluminium cylinder you can see is my own make non return valve. This may need to be lower so that the head of fuel puts a bigger closing action on it, but tests first.
I like using R/C Car tanks on boats, far less fiddly to fill. These were borrowed from a Hyper7 and an XT2 (wish I could get small parts into my sheet bender ):
So all being well I can run tomorrow after the throttle linkage challenge, then the rudders to think about. Balance point is 1/3rd from the transom at the moment.:
Name:	TEST AIRBOAT 4.jpg
ID:	1915256   Click image for larger version
Name:	TEST AIRBOAT 5.jpg
ID:	1915257   Click image for larger version
Name:	TEST AIRBOAT 6.jpg
ID:	1915258   Click image for larger version
Name:	TEST AIRBOAT 7.jpg
Old 09-01-2013, 02:43 AM
St.Marek
Hello Jeremy.
Iterestingly fixed drive. What is the purpose of the use of such power? ? ?
You have a well-equipped workshop. Nice lathe and milling machine.
These works perfect machine. What kind of companies are these machines? ? ?
Greeting from Poland
Marek&Wojtek
Old 09-01-2013, 08:50 AM
Jeremy_H
Jeremy_H's Avatar
Marek, the purpose is really just for fun, something different .
The lathe and milling machine are Chinese manufacture, they are sold around the world with different names, in the UK 'Clarke', 'Axminster' and the people I bought mine from 'Amadeal'. In the US they are mostly have the name of 'Grizzly'. They are simple machines, but with some work they can be made much better.
Old 09-01-2013, 02:29 PM
Jeremy_H
Jeremy_H's Avatar
http://www.youtube.com/watch?v=SOeirMMLXYw&feature=youtu.be
Lot's resulting from this! Haha!
List:
Mount needs a little bracing. Not the engine mount itself, the pylon or riser is moving a little on the aft end.
Fuel tanks need to be a little higher
Both fuel filters letting air in
Prop balance to be re-checked on the aft engine
Throttle linkage is a joke
Old 09-01-2013, 04:24 PM
Jeremy_H
Jeremy_H's Avatar
Just a little diversion....
I've found some dogeared prints of two of my previous boats, These are scans and they may help to show what the target boats will look like as they are a development from these.
This is the first of this style during build, the one I showed previously with the tiger stripe paint:
And this was a subsequent one. This is actually a pattern or 'plug' for a GRP moulding, one was popped out of the moulds which worked succesfully, but sadly the moulds are not accessible any more, c'est la vie!
Name:	AIRSHARK PRE PAINT.jpg
ID:	1915631   Click image for larger version
Name:	AIRSHARK ASSEMBLY.jpg
Old 09-02-2013, 02:44 PM
Jeremy_H
Jeremy_H's Avatar
I've braced the pylon, Brunel would be proud of me
Name:	TEST AIRBOAT 8.jpg
Old 09-03-2013, 03:41 AM
asmithnc
asmithnc's Avatar
Great build.... made me think of the inline twin I built back in 2005. Engine mounting and throttle linkage was perfect but the COG was off. Scraped project after first water test.
http://www.youtube.com/watch?v=8lAxlQANbXI
Old 09-03-2013, 09:26 AM
Jeremy_H
Jeremy_H's Avatar
Ooh! Very interesting to see! Love that sound
I'd love to have an idea of where your CoG was. So much of yours is different to my current ideas, but mine is based on a predecessor so I'm sort of using that experience to design the twin.
A reminder of the original, and the new concept final design for mine:
Key points:
The final hull is not a flatty, it's my own variation where there is much lower lift on the bow because the wetted volume decreases moving forward, so it rested bow down. I had to add a mass of lead as ballast to the rear of the boat, I don't know the weight but I can tell you it was a 1" cube of lead, and it was sat over the very stern of the boat, quite substantial. Correct me if I'm wrong, but looking at yours it was sitting stern down too much? My engines are sitting much further forward, and I'm betting on the rear engine slightly counterbalanced by more volume forward on the hull will balance. QED . If your issue was not fore and aft then this particular perception of mine falls to pieces lol!
Turning to vertical balance is where I have to disagree with your install being perfect. Prop clearance on mine is to be a minimum, in reality below deck level as the deck is recessed. Just enough clearance to be safe, say 10mm. Engines are side mounted, this puts the silencers below crankshsaft height making a huge difference alone, but add the cylinder/head shift to the side and the CoG drops substantially.
My fuel tanks where never going to be up with the engines, the yellow boat above had its tank in the cowling behind the motor, and with this design hull I'd have a complete shift in handling as the weight reduced during running. It went from flattish turns on a full tank to a touch of spin-out oversteer on a near empty one, because the boat's centre of drag shifted forward as the tank emptied, hence lever advantage meant less slip and more dig and turn, not acceptable changes (bear in mind we are talking water rudder here). This is another reason why my tanks are to be much lower, and as close to the desired CoG as I can get them. The closer they are to the desired Cog the less impact fuel use will have on that CoG's actual position. This has to be coupled with hydrodynamic issues as pure CoG changes alone may be pertinent to an aeroplane, but not to a boat, because the weight of the boat changes the submerged volume changes. Hence, potentially, the operation of the boat will shift in ways other than sluggishness, it may steer completely differently as the centre of drag the steering has to pivot around can move as the boat rises. With two engines, the weight of double the fuel is not a factor which can be largely ignored with many regular boats. So these variances to yours, engine attitude, height and tank position/height, mean my CoG is going to be very much lower, I wonder if yours was detectably top heavy in turns? I get the impression the boat would heel a lot.
My test boat is yet to get wet, I'll see how it sits in water this evening.
Whatever, it's great to see another one, sorry to hear it didn't work out, I hope those two lovely engines of yours are in happier homes
Name:	AIRBOAT V2_IC.jpg
ID:	1916357   Click image for larger version
Name:	AIRBOAT UNDER WAY.jpg
Old 09-04-2013, 03:17 PM
Jeremy_H
Jeremy_H's Avatar
Now working on the air rudders. Early days, and I may stick a basic water rudder on in in the interim so I can use it this weekend, as I've never made an airboat with air rudders before and I've a lot to learn. But a start has been made:
Now, here's a thing. I've often made parts out of a simple cold layup of Carbon Fibre, Would this be a suitable material to use for the air rudders on the final boats? In my head stiff and light is just what's needed. This is an old moulding of a powerboat screen I did some years ago so show what the surface would look like:
Name:	TEST AIRBOAT 9.jpg
ID:	1916722   Click image for larger version
Name:	TEST AIRBOAT 10.jpg
Old 09-05-2013, 02:06 PM
Jeremy_H
Jeremy_H's Avatar
Made up the rudder bearings, and some rudders with material I have, I'm thinking they should be bigger judging by other poeple's, but I've no idea how effective these would be.
What do you guys think?
Now I can do a float test, bathtime!
Name:	TEST AIRBOAT 11.jpg
ID:	1917034   Click image for larger version
Name:	TEST AIRBOAT 12.jpg
ID:	1917035   Click image for larger version
Name:	TEST AIRBOAT 13.jpg
Old 09-05-2013, 03:07 PM
Jeremy_H
Jeremy_H's Avatar
All went well:
Name:	TEST AIRBOAT 16.jpg
ID:	1917041   Click image for larger version
Name:	TEST AIRBOAT 14.jpg
Old 09-06-2013, 05:35 PM
Jeremy_H
Jeremy_H's Avatar
Ups and downs today.
In effect, it's ready to run. Bar the pusher prop, which is a can of worms again because my order has been cancelled due to faulty stock . Back on the phone again tomorrow.
Finalised the rudder linkages and radio installation today. As predicted the rudder control rod path was too much for a single servo, so I put two in. The final boats will have a much straighter path for this link.
Name:	TEST AIRBOAT 19.jpg
ID:	1917340   Click image for larger version
Name:	TEST AIRBOAT 18.jpg
Old 09-08-2013, 01:57 PM
Jeremy_H
Jeremy_H's Avatar
The pond session started badly as my radio gear went pear shaped in a big way, chattering servos and rudder lock over to start with, then channel swapping would you believe!! I don't know, but it went in the bin when I got home. Prior to that at the pond a freindly club colleague lent me his receiver and transmitter so we could continue with the tests, good man! :-)
In short, this lumpy boat couldn't get over the hump on to the plane on the one engine, it was on the edge of it downwind but ploughed somewhat the other way. It'll be interesting to see just how much difference the second engine will make.
Original rudders were respectable, but the next size up fayred better, I'll hold off on final judgements when I've got more thrust to deflect. I could get a comforable turning circle, but without being in a skimming mode it's a load of freeboard to turn in the water.
The fuel setup allowed me to empty a tank on the final run, but I didn't raise the tank height before trials as I said I would, so I'll get into that as I'm haviing to run rich to keep the draw, and that was flooding the glow plug on sharp throttle offs.
Name:	TEST AIRBOAT 20.jpg
Old 09-08-2013, 03:41 PM
yellowufo
What is the auw on this rig???
Old 09-09-2013, 08:54 AM
Jeremy_H
Jeremy_H's Avatar
Oh it's a monster mate, I've just weighed it for you on some accurate scales, 13lb 3-7/8 oz !!
