RC Airboats Discuss R/C Airboats here!
Length from Stern?
Reply
Old 04-11-2014, 01:13 AM
Croc Man
Croc Man's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Length from Stern?
Hi, on a 40inch flat bottom build, with a 31cc Zenoah, what would be the distance back from the stern that would be a good starting point for
the Engine? Does 7inches sound correct from stern to piston centre? Cheers.
Croc Man is offline
Old 04-11-2014, 10:09 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pusher or puller prop will define where you should start. Generally you want the prop at about 1/3 (hull length) from the transom/stern. On a 40" hull that's about 13.3". This is for a puller configuration and is a starting point only. Either puller or pusher will require moving the engine around to find the perfect balance. I don't use pusher configurations on any of my boats so I can't give you a starting point for that. I don't believe the same "rule" applies to pushers.
1QwkSport2.5r is offline
Reply
Display Modes
