RC Airboats Discuss R/C Airboats here!
Jett 56lx hull swap
Reply
Old 07-12-2015, 08:02 PM
crispyspa
crispyspa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Jett 56lx hull swap
Got to throw some boats in the water over the 4th. Two of the boats had to endure a bit of surgery. We ran one boat, took speed measurements, and then swapped hulls to see the difference in hulls. Here is a video of the whole process.
https://www.youtube.com/watch?v=3Jt-jzcOJVg
crispyspa is offline
Old 07-14-2015, 01:03 PM
Jeremy_H
Jeremy_H's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I must see if Jett post abroad, they look like superb engines
Jeremy_H is offline
Old 07-14-2015, 03:51 PM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am sure Dub will ship outside of the states. All engines are made to order and are usually subject to a 2-4 week lead time for BSE engines and closer to 2-weeks for cast case engines. Be aware if you decide to get one of these engines - you need a good and solid test stand, a well balanced propeller, a bubble-less fuel tank, and a tachometer. These engines require more finesse to setup, break-in, and tune. Dub's instructions are very clear, so long as one follows those instructions, you'll have good luck. These engines blow most all other engines away in power and looks. 18,000rpm on a 10x6 from a 9cc mill is just crazy power. Roughly 2.5hp. jett2008@jett.engineering.com Omit the period between Jett and engineering. Damn spammers.
1QwkSport2.5r is offline
Old 07-15-2015, 05:47 AM
asmithnc
asmithnc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great try guys. You still need 10.2 mph to beat me . With that long straight you had.... let her keep going. Might pick-up 3-5 mph per 200ft.
asmithnc is offline
Old 07-15-2015, 06:00 AM
asmithnc
asmithnc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
https://youtu.be/ZO-PAQTypMs
asmithnc is offline
Old 07-15-2015, 06:15 AM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm gonna re-do the sponson profile on my hull and see if that makes a difference. I think the radius got knocked out of spec after I glued the sponson on and sanded the skins mating surface flat. I'm also going to change out the whole rudder assembly and probably change out the servos for some lighter ones. It needs to lose a little more weight and get that sponson profile perfect. My engine is still detuned a lot - it still needs to break-in more before I cut the final 1/2" off the header to get the prop turning 18,000rpm+. In the video crispy posted, the engine is running at 16,500rpm which is well below what the engine is capable of. We'll have a revisit next summer if not later this year.
Old 07-15-2015, 09:17 PM
crispyspa
crispyspa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh man Andy...The MS-54 boat is legend. Oh, by the way Andy, you happen to have any turn fins? After the engine swap I lost mine. I was so bummed.
Old 07-16-2015, 03:51 AM
asmithnc
asmithnc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll see what I still have...
asmithnc is offline
Contact Us Archive Advertising Cookie Policy
