RC Airboats Discuss R/C Airboats here!
1.5mm carbon fibre rod
Reply
Old 06-12-2016, 02:49 AM
Paulekins
Paulekins's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 1.5mm carbon fibre rod
hi all i am wanting to build a cage to go around my propeller (11x7) on an air boat i am thinking of making
i was thinking of using 1.5mm carbon fiber rod as it is lighter than steel
what i would like to know is will i be able to bend it into a 12 inch diameter hoop or will it just shatter at that size
i have found a glue i can use (http://www.easycomposites.co.uk/#!/r...-adhesive.html )
for gluing the ribs etc i just wasn't sure how far i could bend this stuff
Paulekins is offline
Old 06-12-2016, 05:13 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its gonna snap. Hollow or solid won't matter. 1.5mm is nowhere thick enough to protect the prop anyway. That is unless you used a stiff metal wire. Why do you want a prop cage on your boat? Just for the "scale" looks?
1QwkSport2.5r is online now
Old 06-12-2016, 06:03 AM
Paulekins
Paulekins's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no to save my fingers
Old 06-12-2016, 06:16 AM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Don't stick your fingers in the prop.
FWIW, a lot of guys don't use prop cages including myself. If you insist on it, You will need to find some sort of wire that can be soldered or twisted together. The first thing that comes to mind would be brass rod in a small diameter... It solders nicely, but it's very heavy.
Old 06-12-2016, 06:33 AM
Paulekins
Paulekins's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the first one i built was with piano wire but it still had a bit of weight to it which is why i thought of using carbon fiber the same as fishing rod
which can take a fair old bend to it i am just not too sure how much bend i can get in a 1.5mm rod
Old 06-12-2016, 07:01 AM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It will bend, but I have my doubts you'll get a 12" hoop from it. Only way to find out though...
Old 06-12-2016, 07:04 AM
Paulekins
Paulekins's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thats why i was asking the forum before splashing the cash
Old 06-12-2016, 07:35 AM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Knowing how fiberglass and carbon fiber like to bend, I don't think it'll work... I have a feeling you're gonna need to spend some money and do an experiment. Most if not all prop cages I've seen were made of steel wire/piano wire.
Old 06-17-2016, 04:38 AM
Paulekins
Paulekins's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well i wrote to the suppler and they have informed me that they will bend up to an 8 inch circle
so i have some on order i will let you all know how i get on
Old 06-20-2016, 12:46 AM
Paulekins
Paulekins's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well it arrived rolled up in a 9" jiffy bag so yep it bends
just ordered some 3mm for the main frame work of the prop guard we will see how that bends next lol
Old 06-23-2016, 10:06 AM
Paulekins
Paulekins's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it arrived today the 3mm carbon rods so with eyes squinted i slowly bent the rod and managed to bend it into a 12" circul
so i just need to sort out the scale of plans and i can get started
Reply
Display Modes
