Go Back  RCU Forums > RC Boats > RC Airboats
Gas tank position - below motor??
RC Airboats Discuss R/C Airboats here!
Old 03-06-2017, 06:57 AM
MarkPrima
MarkPrima's Avatar
Question Gas tank position - below motor??
Hello,
I'm really confused with this issue. I just built a small airboat with a OS MAX 25FP and I mounted the gas tank (6oz.) below the motor but I am having trouble with the fuel siphoning and having to constantly prime the fuel line. Do people use something like a one-way valve in the fuel line?
How do you guys do this? I'm baffled.
Old 03-06-2017, 11:22 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Originally Posted by MarkPrima
Hello,
Having the tank below the engine will likely siphon back to the tank unless you clamp the fuel line or close the throttle completely. The airbleed carb may cause it to siphon back regardless.
When the engine is running, the fuel should not siphon back due to the fuel draw of the engine. The only way to combat the fuel siphoning is to mount the fuel tank behind the engine ensuring the center of the tank doesn't sit above the center of the carburetor (spraybar). Do not use a check valve in the feed line - you will have carburetion problems.
Old 03-06-2017, 01:01 PM
MarkPrima
MarkPrima's Avatar
Thanks, I may redesign my next air boat and have the fuel tank behind the motor as you mentioned. But I do like the looks of having the fuel tank below.
Old 03-06-2017, 01:09 PM
1QwkSport2.5r
Most engines will draw fuel fine when the tank is right under the engine - any more than that and the engine may have issues.
Old 03-06-2017, 07:24 PM
NEW222
Ooohhh. A home designed airboat. Do you happen to have pictures? Would like to see it. Thanks.
Old 03-07-2017, 03:21 AM
MarkPrima
MarkPrima's Avatar
Yes here are my build photos. It is shaped out of pink insulation and then sheeted with oak veneer.
Here are plans for my first electric air boat - I still run this one - goes good in show - flyingblog.primaveraphoto.com/snow-water-bug-prototype-and-plans
ID:	2204283   Click image for larger version
ID:	2204284   Click image for larger version
ID:	2204285   Click image for larger version
ID:	2204286   Click image for larger version
ID:	2204287   Click image for larger version
ID:	2204288   Click image for larger version
ID:	2204289   Click image for larger version
ID:	2204291   Click image for larger version
ID:	2204292   Click image for larger version
Old 03-09-2017, 07:44 PM
NEW222
That looks very nice. Congrats on the build, and thanks for sharing.
Old 03-09-2017, 09:51 PM
crapshooter
you still have enough space to put the fuel tank behind the engine. having the tank down low will not only effect starting and running issues but also you will get lean runs which is no good for the engine.
Old 03-10-2017, 12:14 AM
1QwkSport2.5r
There's no issue with the engine drawing fuel with the tank underneath the engine. I have done some testing with a fuel tank 6" below the engine and.3" behind it and the engine ran well. You have to compensate with the needle settings a bit. Lean runs happen because of improper needle settings. The FP engines have tiny Carburetors, so they draw fuel well. Other than fuel siphoning when the engine isn't running, there should be no other problems.
