What is this airboat?
Hi, I received this airboat (hoping pics load) as part of a package deal of planes. I haven't been able to find it online, after a couple quick searches. Any thoughts or information anyone has on it would be helpful. Thanks.
It is...
This is a flightcraft, Probably the Miss Outlaw. I can tell by the type of stand that it has with that rope like mine has. With a 40 size, 9x6 2 blade . 46 ball bearing to a 52 is best suited with a 9-6 3 blade. Unless you raise the engine up I would not put a 10 in propeller on there it will be too high and be Tippy. mine is the river rage and it has turn fins. It is too easy to hit logs and other objects in the water with a water Rudder and that also drags it down and makes it squirrely. There are no spare parts unless you can buy a complete boat. You can Google search :Vintage flightcraft River rage and see pictures of "dragnfly". This is the best handling flat bottom boat that is out there today because of the way it is designed. It's too bad they don't make them anymore. I hope you enjoy your model and maybe we can hear from you again
