RC Airboats Discuss R/C Airboats here!
60cc airboat maiden voyage
Reply
Old 12-05-2017, 10:40 AM
jjonas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 60cc airboat maiden voyage
Maiden voyage my scratch-built airboat the other day! I feel lucky to find open water here in Montana in December, but it probably won't stay that way for long.
Only got to about 1/3 throttle as I was a bit timid with it. Looks like it could use more weight up front?
The cage is made of steel and I've thought about reconstructing it using aluminum to shift the balance forward.
I'm hoping to test out the FPV and auto-pilot soon.
ID:	2247014   Click image for larger version
ID:	2247015   Click image for larger version
jjonas is offline
Old 12-06-2017, 07:02 AM
Lester Burch
Lester Burch's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What is the size and weight of your boat.
It looks good.
Lester Burch is offline
Old 12-06-2017, 08:00 AM
jjonas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks.
It's 3' x 5' and weighs about 45 lbs. The cage alone weighs 15 lbs. I think one made out of aluminum would only weigh half as much.
jjonas is offline
Old 12-06-2017, 08:39 AM
Got RPM
Got RPM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Where is the CG now? You won’t know if it is right or not until you can give the boat full throttle.
Got RPM is offline
Old 12-06-2017, 02:04 PM
jjonas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good point. Once we get better weather, I'll have to go see what it can do and how it responds.
The CG is about 1.5ft forward of the transom, putting it at about 1/4 of the entire hull length (measured from the transom).
jjonas is offline
Old 01-09-2018, 03:01 PM
ElectricFlyGuy
ElectricFlyGuy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can see why you are hesitant to go much past 1/3 throttle as it may just be top heavy and it seems to sit low in the water. But, you found some nice smooth waters and that is the best kind in that case. It would take some force to uproot it and flip it over. I hope you are prepared for a flip over and the question is, is it very buoyant just in case? Is that box well sealed? If so, then I would say yes it won't sink. My electronics are in a water proof RC case built into my boat. I wouldn't go fast while turning until you build that aluminum frame/cage. I put mine trough heck and it's very stable with my aluminum framework.I'm sure you would have no trouble going near full throttle on smooth water and with as much as it weighs also holding it firmly in the water. Let us know what changes you make and I think a 36" width makes that a very stable boat at 5' long for sure! Very nice! I would like to build a 6' X 3' and was wondering is you did a build thread or if you took build photos? IF not, can you tell us how it is constructed? What plywood? Fiberglass? Your hull don't look very deep. I think the height should be approx 6" to at least 8" ( per your scale) to really float and maneuver well. Thanks. Scott
ElectricFlyGuy is offline
