Largest scale airboat built
Hi all: I was wondering who has ever built a large scale air-boat and size and specs if possible. Mine has an 18" overall height , and is 33" long by 4" high (hull only) and 16 1/2" wide sporting a Leopard LBP3674 @ 1900kv motor spinning a 1060 prop. This boat scoots!! I want to build or have built for me a larger scale and I'm talking about 6' long by approx 2 3/4' wide or what ever proportionately correct. I could supply the air-boat will the much larger motor and prop needed. If anyone locates plans and even free plans, please post them here. Maybe Tom of Expresscraft might be up to the task of building me the hull or 'box', and all I need to do is outfit it, since he has more experience and materials.. In the meanwhile, I'll just play with mine....Can you do that Tom? And maybe sometime me and the wife can make the trip since we are in Palm Coast... Thanks everyone for your help and always open for tips and suggestions.
I also ran across this post from 2013 using a GYRO and it is a great idea for air boats,but how would they plug into the normal 3 channel ESC's in which we only use two channels anyway? Is there a place such as the AUX to plug the one plug into? Thanx.
OK, tried posting the link and I got a message that I needed at least 10 posts before I can post a link. Now I could have sworn I had hundreds upon hundreds of posts since I joined. I guess someone did some programming and their skills show...........
What control would you want the gyro to manage? I used one in head-holding mode on a SAW hydro rudder servo for maintaining a constant heading to counteract prop walk. It plugs into the wiring between the receiver and the servo, I turned it on and off without the third channel. How would this be an advantage in an airboat.
