my very first airboat, with PIC's
WI
well how is it,, it's made with standard airplane servos, a .19 engine, balsa wood, plywood, and pink styrofoam(for color), and a 10x6 puller prop,
My Feedback: (21)
RE: my very first airboat, with PIC's
VERY nice ....
Might I throw a few suggestions to you ?
The rudder can be cut down a bit ( the size of the prop is usually a good starting point ) and also , by the picture , the angle of the prop to hull looks like you might get some porpoising effect ... ( the nose of the boat bouncing up and down ) . Make the prop angle 90 degrees to the hulls bottom
Next , the foam is good , but , you might want to coat it with something so it doesn't come to peices on you .
Are you gonna run on snow/ice , or just water ( whenever the heck it decides to thaw - ) ?
One more thing ... your radio gear ( Rx and servo's ) , you might want to either "waterproof" them by using something like CORROSION X or put them in a watertight box ( one of those cheapo ZIPLOCK sandwich plastic boxes will work ! )
You get those wet and you loose control ...
Otherwise ... congrats on your new build and best of luck with her .
And most important over ANYTHING .... be CAREFUL ( with that prop ) and have FUN !
WI
ORIGINAL: TERBObob
VERY nice ....
VERY nice ....
also how do you think the way i made the hull (with 2 pontoons instead of a flat hull) will fair in open water,
my dad thinks the motor mount wont hold what do you guys think.
My Feedback: (21)
About the motor mount ... did you reinforce the bottom ( add a plate- if you will ) for the bolts to travel thru and add strength ?
Meaning .... did you take a piece of aluminum , or wood ( thin ) , and cut it the distance of the width of the sponson for the bolts , from the top section of the mount ( that is viewable in the pictures ) to go thru the foam and thru the plate ? Did you also use fender washers on the bottom part where the nut connects to the bolt ?
If yes , then , IMO , she should hold up ...
If your still in doubt , you could also throw some glass and resin on the mount where it meets the foam for added support .
Oh ... and how will it work in the water with th twin pontoons ? Just as good .... that should not be a problem ....
Think of a Catamaran ( sailboat )... basically same thing ...
WI
ok, i have the darker piece of wood reinforced very well what he and i were worried about was where the motor actually connects to the piece of dark and light wood, im thinking of running 2 or 3 bolts all the way through and then adding a lock washer to the bottom to keep it from getting lose.
what do you think
what do you think
I'm kinda with your Dad on the engine stand. If that engine comes off it will cause some pain and a high Dr bill. The rudder can be a lot shorter. I agree with Terbo, make the foam stronger, you don't want that to break while you are starting her.
The props may be small, but they will open a can of whop@$$ on you in a heart beat.
WI
ORIGINAL: haljmac
ON, CANADA
You might have a little problem with water going in the prop, but dont worry about it unless it does happen. I would reinforce the sponson, and the servo will probably have trouble to swing the big rudder, but gotta try it full throttle to find out. Just my 2cents
WI
ORIGINAL: rcairboat78
Hey, where is the fuel tank?
WI
Other than the suggestions that have already been given, I would make one more............use a smaller diameter prop.
A 10-6 prop is much better suited for a .40 size engine. A .19 will have a hard time swinging it at any reasonable rpm and will load the engine down and cause over-heating. Bigger is not always better.
For a .19 engine, you want to be running an 8-4 or 8-5. At the most, a 9-5.
