Swamp Buggy woes
Swamp Buggy woes
Question, I finnally trimmed out and balanced my airboat [Dumas Big Swamp Buggy], Ran real well. I adjusted my engine angle w/washers and installed a 10-7 prop on my LA 40 and wow. Until I plowed it into a concrete bulkhead that surounds my test pond. I seem to loose steering at a high planning speed. At half throttle it turns on a dime, or burst the throttle with the controls maxed it turns well. Why does it loose control at high speeds? Is this inherrent to the model? I looked at the control rods, while they are flexible but they seem stiff enough. Maybe not. I am going to glue it all back together and make a fiberglass mold out of it, and need some sugg. or input before I attempt this design again.
Thanks for your time.
Keester
Keester
RE: Swamp Buggy woes
I see what you mean with a flat bottom, but this is a tunnel hull and turns on a rail at 1/2 throttle. No sliding.
Keester
Keester
WI
Being a tunnel hull, you may want to try a turn fin (as long as it will only be run on water).
To make it work equally to turn in both directions, mount it to the hull bottom, about 1/3 the hull length from the transom (or...slightly behing the cog).
Make it, so when you look at the hull from the side all you can see is a portion of the fin about 1/2" tall and about 2" long. The actual size will be bigger due to part of it not sticking out below the hull bottom.
A simple way to make one would be to bend a piece of brass strip into an 'L' shape and screw it into the hull bottom.
ORIGINAL: Keester
Keester
Keester
MN
Are your rudder/ rudders big enough ? As this tunnel gets going faster it tracks on the sponson rails and with the wind speed of going faster - turning is less effective.I would try bigger rudders / more throw -before adding anything below the waterline as there are lots of weeds and crud where I usually run.
