RC Airboats Discuss R/C Airboats here!
BIG SWAMP BUGGY
Reply
Old 09-03-2008, 01:22 PM
  #51
shinobid
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: BIG SWAMP BUGGY
I built a big swamp buggy quite a while ago, and from my experience with RC planes, I knew that the placement of that fuel tank below the engine seemed a little odd to me, so I added the "header tank" modification to it right away!! I zip tied it to the back side of the engine tower. It works sweet!! Also, I did the pull, pull method for the rudders so that the servo is never under any strain whatso-ever because it never has to "push" the rudders. This is easily achieved by just running a cable from the inside of each rudder to each side of a dual servo arm. I also used a turn buckle type connector for attaching the rudders together, replacing that stupid brass flat bar connector. This is good for adjustment purposes when building to make sure they are parallel...Anyway, I know this ios an old forum, but I stumbled upon it surfing around this site and thought I would throw in my .02....
shinobid is offline
Old 11-02-2008, 08:44 PM
  #52
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got a Dumas swamp buggy...I think I will put a 18-22cc gasser on it. I bet she will zim right along!!! Or maybe toss the ignition and run it Gas/ glow!!! Capt,n
captinjohn is offline
Old 04-13-2009, 04:43 PM
  #53
Badfish67
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Almost done with mine...here are a few pics. Anyone have any ideas for a fuel tank holder?...I need a strap or something so the tank dont move around.
ID:	1179728   Click image for larger version
ID:	1179729   Click image for larger version
Badfish67 is offline
Old 04-13-2009, 06:49 PM
  #54
asmithnc
asmithnc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Badfish67
I not a BSB guy but yes you need a strap or rubber bands to hold it in place. But where? If you had more room I would go with zip ties. But since you don't try rubber bands three in front a three in the back.... one on top of another.
Wake county is not too far away. We have a great pond in Greensboro and we have plenty of different airboats you are welcome to come . I have no idea if you are new to airboats but if you need help were here. Andy
asmithnc is offline
Old 04-13-2009, 09:30 PM
  #55
Badfish67
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Andy...Yes this is my first air boat, I have had many other boats but no air boats. I was thinking of rubber bands but not sure how I would set that up. Maybe put a small dowel on the top and another one on the bottom, then do the rubber bands cross ways. I only need them in the front because the back is held in by the slant of the engine mount.
Old 04-13-2009, 11:15 PM
  #56
knbaudio
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
a bunge the girls use on there hair i took one of my daughters black ones and it work great the fuel doesn't break it down i use them on all my boats tanks and radio boxes now.
knbaudio is offline
Old 04-14-2009, 05:54 AM
  #57
Dreamin Hemi
Dreamin Hemi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Always loved these BSB's. Had one maybe 15 years ago??? Powered first by a .61 K&B than eventually a Supertigre .91...now that was fun!
For the tank, I remember using foam rubber below the deck for vibration as the fuel tended to lean out with the foaming, and using zip ties to hold the tank in place.
Dreamin Hemi is offline
Old 10-30-2010, 05:26 PM
  #58
ckelloggjr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pete,
Are you still out there? I'd like to talk about how you finished your Swamp Buggy.
Thanks, ckelloggjr
ckelloggjr is offline
Old 07-31-2012, 03:14 PM
  #59
andyb0831
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi,
i built one of these babyies about 20 years ago and put a .65 on it.  it barely touched the water, i had a small sailboat hull i flipped upside down and glued it to the deck and made a cockpit and pilot to man it.   i'll look for the old pics and post them.  i did it in red and a coka cola theme.
i recently ordered the plans and despite the negativity i have heard about the satisfaction with them i found them excellent.  my boat is going to be 46" long.  with pictures that folks posted of their builds and the fact it is stated that the boat is 31" i was able to determine the width and size the templates to what i wanted.   i had to enlarge the template width to about 340% and the length the template to a little 0ver 600% to make them proportionate.  all the other parts i can sort out once the skelleton is built.  i am going to have someone fabricate the engine mount out of stainless.  instead of those two little rails to screw the proposed engine mount to i am going to make that whole platform a harder wood. maybe epoxy a metal plate under there.
not sure how i am going to power this beast.  am going to build this one to look like an authentic everglades airboat, with a gi joe type driver and all. i may turn the engine pod around and make it a pusher with a 3 prong blade. definately move the rudders further apart and a little longer than scale.
forward ho!
andyb0831 is offline
Old 06-08-2013, 08:24 PM
  #60
Twin_Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I recently picked up two of these, but both incomplete. One is missing the rudders and the other the entire engine stand.
i can figure out the stand from the one i have but need template or at least the measurements for the rudders and how they are supposed to be mounted.
Bill S.
Twin_Flyer is offline
Old 06-09-2013, 03:37 AM
  #61
knbaudio
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey bill it's been ten or twelve years now but I only have one with the stock rudder. The others I did had different shaped rudders the last set I did looked like old bomber plane rudders alittle larger than the engine stand and worked the best. I have a single rudder and twins from small to large.
knbaudio is offline
