IS THIS TRUE?
IS THIS TRUE?
I HEARD THAT THE SPARK PLUG ON A WEEDEATER ENGINE WILL MESS WITH THE AM RADIO...AND THAT YOU NEED TO GET FM IF USING A WEEDIE...IS THIS TRUE?
RE: IS THIS TRUE?
NO.....If your spark plug wire is not insolated, and you have sparks jumping on the outside of the engine or if your using a high preformance plug wire, it may cause interferance with any radio am or fm. Any metal to metal rubbing will make the radio glich.
