plexigalss hulls
AZ
RE: plexigalss hulls
A flat bottom hull wouldn't be too hard. Anything is possible with enough $. Because it's who you know not what you know. Also a cool idea would be to put a small video camera on it and drive in some shallow (5-10 feet) clear water. That would be interesting.
MN
I made one once I used 1/8" clear plex with 1/2" pine for the sides and transom of the boat - It has been so long ago I forgot what I used to glue it to the wood - I think CA. then sealed it with clear silicone. It did look pretty cool - at first .. then stress cracks satrted developing all over, and it was so brittle you hate to run it aground. I took some pic's of it way back when.. I will see if I can dig em out someday soon.
If I had to do it again - I would do the wood sides with 1/4" plex -mounting the engine to the side rails(sides)
It is actually very possible. I built some models out of acrylic (plexiglass) before, and you can easily curve it and shape it to form any shape hull. You would need to make a mould out of wood or something in the shape you want. Then you heat up the acrylic in an oven (I forget, guess maybe 300degrees for 5 minutes or so) and it gets very soft and flexible. I'm sure you could do some gentle compound curves. Once it cools it goes back virtually to its original strength and rigidity. It takes a bit of experimenting though.
