RC Airboats Discuss R/C Airboats here!
WINDY with a .25
Reply
Old 07-01-2005, 11:48 AM
BMX invasion
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default WINDY with a .25
I am building a dumas windy air boat, as big and heavy as it is how can a .10 move it? I have a OS LA .25 on a airplane and was wondering if it would work on the boat? It would be very powerful but thats fine. I am going to use a balloon fuel tank (a regular stopper with a balloon tied to it) because of how small the fuel compartment is. Should I use the keel because I would like to be able to drive it on grass and snow. How do they handle w/o the keel? I have heard that some people don't use the keel while others do. I have never built a air boat before so I don't know how they handle with a keel and ware should the CG be located.
later Zach
BMX invasion is offline
Old 07-01-2005, 02:05 PM
ballgunner
ballgunner 's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: WINDY with a .25
I run my Windy with a .10. Big mistake. A .15 is a good engine for this boat and it would probably take a .20 but I wouldn't go larger than that. It will run well on grass and snow without the keel but a keel is needed for running on water.
ballgunner  is offline
Old 07-01-2005, 03:45 PM
dadkins
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think you should try the .25 - I always like em a little overpowered. You just have to teach your trigger finger when enough is enough.
dadkins is offline
Old 07-01-2005, 07:38 PM
BMX invasion
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What do I do about prop clearance for the deck. The props I have are two blade and will be to big so should I go with a 3 blade. Will the extra thrust help or should I go with a smaller low pitch prop and not load the engine up much? one more thing when painting it should I paint it first then seal it in epoxy or epoxy it first then paint it?
later Zach
Old 07-01-2005, 08:50 PM
BMX invasion
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Theirs a lot of F#$*!IN sanding on this thing[sm=bananahead.gif]. The pretty sides are a real killer. I'm done most of the sanding and covered in spruce, birch, and mahogany dust but it's all worth it it's pretty cool looking with the angeled sides.
later Zach
Reply
Display Modes
