View Poll Results: A poll
Same brand radio and servoes. Any brand.(please explain)
0
0%
Radio is important but any servo will do.
0
0%
Servo is important but any radio will do.
0
0%
Voters: 9. You may not vote on this poll
What is your usual radio servo set up?
WA
What is your usual radio servo set up? Please tell me why. I'm not looking for a ford and chevy thing but your opinion why you think your set up works best.
Shawn
Shawn
My Feedback: (12)
SC
RE: What is your usual radio servo set up?
I use Futaba and Hitec servos. Both have done well. I size them based on the application. Throttle usually gets a standard servo, although sometimes I use a smaller servo. I size the rudder servo based on the size/speed of the boat/plane.
I have different sets for different models , Traxxas, Acoms, Futaba and Hitec. Servos range from mini to 1/4 scale servos (large) and some with metal gears. for heavy steering, My airboat that i am building now, will be fitted with the Traxxas 3 channel RX and TX and using standard futaba servos, i might fit a servo saver to the steering servo because the big rudders take a lot of knocks fom the prop draft, and cross winds(I might use the metal geared one also??), the 3rd channel for if i use a spoiler to help level the boat at speed.
i get stuff on sale too
My Feedback: (21)
I always use TQ3 radio ( via EBAY ) , with Hitec RX and Servos ( via Servocity ) ...
Reason - I like the third channel for a "just in case" and where I am located , 27 meg is not interfered with , get good clean signal ( 75 meg , have had issues with out on the water ) , is easily found ( TQ3's ) and usually cheap as well )
Hitec Rx and servos - ain't ever had a single problem , glitch , or anyting go wrong with one . Always use standard for throttle and 1/4 scale for rudder(s) .
For my water propped boats , I run a little different setup . I use hitec Tx, the rest stays the same , other than that , I DO use 75 meg for those ( even though I do get glitches once in a while - but ... thats what failsafes are for too )
